Thread: Blend Door Actuator or Temp Controls?
Results 1 to 20 of 20
lemkeant Blend Door Actuator or Temp... 06-01-2012, 10:54 PM
Scottydoggs Re: Blend Door Actuator or... 06-01-2012, 11:47 PM
lemkeant Re: Blend Door Actuator or... 06-02-2012, 08:08 PM
stealthee Re: Blend Door Actuator or... 06-02-2012, 08:26 PM
Scottydoggs Re: Blend Door Actuator or... 06-02-2012, 08:18 PM
lemkeant Re: Blend Door Actuator or... 06-03-2012, 10:21 AM
lemkeant Re: Blend Door Actuator or... 06-26-2012, 09:27 AM
lemkeant Re: Blend Door Actuator or... 08-02-2012, 02:27 PM
02gt Re: Blend Door Actuator or... 09-30-2012, 05:58 PM
Scottydoggs Re: Blend Door Actuator or... 09-30-2012, 06:10 PM
02gt Re: Blend Door Actuator or... 09-30-2012, 07:06 PM
Scottydoggs Re: Blend Door Actuator or... 09-30-2012, 07:15 PM
02gt Re: Blend Door Actuator or... 10-01-2012, 05:41 AM
TexasTanker19kilo20 Re: Blend Door Actuator or... 04-20-2013, 08:27 PM
TexasTanker19kilo20 Re: Blend Door Actuator or... 04-21-2013, 03:51 PM
TEK310 Re: Blend Door Actuator or... 04-21-2013, 04:39 PM
TexasTanker19kilo20 Re: Blend Door Actuator or... 04-21-2013, 09:32 PM
TEK310 Re: Blend Door Actuator or... 04-22-2013, 06:50 PM
TexasTanker19kilo20 Re: Blend Door Actuator or... 04-22-2013, 10:09 PM
TEK310 Re: Blend Door Actuator or... 04-23-2013, 07:04 AM
  1. #1 Blend Door Actuator or Temp Controls?
    Jun 2012
    Michigan
    Hey Everyone,
    Did some searches on here, and can't seem to find a definite answer, so I'll create my own thread.
    This week Ive began to have a problem where I can turn my a/c on, and its initially cold on the driver side, but then gets hot very quickly while the pass side stays cold. If I adjust the driver side temperature at all (up or down), it gets cold again right away temporarily then hot once again. I should mention I have a trusty 2001 GP with the dual non-digital climate controls.
    The threads Ive seen around here point to a blend door actuator on the driver side, but those symptoms all seem to have the actuator stuck/not working at all? My symptoms are different being that the temperature will correctly adjust but only temporarily.
    Thoughts? Blend door actuator on the driver side, or are my climate controls going bad and I need to replace the climate dashboard unit? Trying to avoid paying for 2 parts when I only need 1 (hopefully). Thanks ahead of time for any help/responses!
  2. #2 Re: Blend Door Actuator or Temp Controls?
    have your a/c tested, that sounds like your low on freon, or R what ever these days.
    the pass side stays cool and the driver side gets warm.
  3. #3 Re: Blend Door Actuator or Temp Controls?
    Jun 2012
    Michigan
    I'm pretty sure that isn't it. Especially since it re-cools itself at any temp adjustment I make. I just had it recharged last year and it was fine all year.
    Living in Michigan, we don't use our air conditioners much
  4. #4 Re: Blend Door Actuator or Temp Controls?
    SWPA
    Quote Originally Posted by lemkeant View Post
    Just because you had it charged doesn't mean it isn't low again. You could have a slight leak somewhere.
  5. #5 Re: Blend Door Actuator or Temp Controls?
    the only thing you can really do is either check the a/c pressure, or open up the dash and watch / feel the actuator and see if its going back and fourth.
  6. #6 Re: Blend Door Actuator or Temp Controls?
    Jun 2012
    Michigan
    Pretty much what I was afraid of. I was just trying to hopefully pinpoint a problem and gets parts ahead of time so I only need to get into my dash once.
  7. #7 Re: Blend Door Actuator or Temp Controls?
    Jun 2012
    Michigan
    Well, slight update, replaced the actuator...wasnt it. I think the sending unit is bad. That was my initial hunch, but the actuator was much cheaper.
  8. #8 Re: Blend Door Actuator or Temp Controls?
    Jun 2012
    Michigan
    And a final update as 2 weeks ago I went ahead and finally replaced the whole temp control panel/unit. Fixed my issues.
    It cost me an extra $27 I didnt need to spend on an actuator, but my heat and a/c now work as intended. FYI for someone in the future!
  9. #9 Re: Blend Door Actuator or Temp Controls?
    Dec 2008
    chicago
    having the same issue,A/C charge is dead on,blend door actuator plunger is operating properly and temp control is rotating,replaced main climate control unit,but still getting luke warm air out of drivers side while passenger side is ice cold,any other suggestions?
  10. #10 Re: Blend Door Actuator or Temp Controls?
    take the drivers side actuator off, and turn the knob by hand if it gets cold you know its the actuator. theres no real way to see the d/s actuator turn with it in the car, its dark and tight in there.
    http://www.grandprixforums.net/blend...ent-21941.html
  11. #11 Re: Blend Door Actuator or Temp Controls?
    Dec 2008
    chicago
    it sure looked like it was turning to me,I could see the outside of it turning back and forth when I played with the temp,I mean I had the bottom of the dash all apart and I could look right at it,unless I am wrong and it was just turning but not engaging
  12. #12 Re: Blend Door Actuator or Temp Controls?
    the outside dont spin, the center hole in the point does, and it moves a very small amount, it only turns back and fourth, maybe a 1/2 inch.
    this is the actuator, that white circle is what turns, see the lines, one right through the center and 2 off to the sides, the 2 to the sides are as far as it turns. one way is hot, the other is cold, the middle is the middle lol
  13. #13 Re: Blend Door Actuator or Temp Controls?
    Dec 2008
    chicago
    Maybe I wasn't clear,but I can see the white circle rotating back and forth,so I know it is operating.
  14. #14 Re: Blend Door Actuator or Temp Controls?
    Sep 2011
    Copperas Cove, TEXAS
    Sorry to revive this thread, but no need to make a new one. There is a lot of good info in this thread so far, but not the answer I'm looking for.
    Problem- Turn on the AC and it blows cold out of the passenger side and luke warm out of the driver side.
    MY fixes so far- I replaced the AC control unit (JY unit)
    I replaced the driver door actuator (JY unit)
    Still does the same thing. Also before when I would select defrost the air would not blow out of defrost vents, after parts it works as should.
    The AC compressor is not short cycling and is operating normal.
    Should I still get a vacuum put on the system to check for leaks and recharged?
    Should I look for another problem?
    Here I'm holding my original AC controler new JY installed
    Driver Actuator, Original Unit
    Driver Actuator, Original Unit other side. Note: The JY unit had a metal rotating piece instead of plastic like the original.
    Just for fun side Note: I noticed the 04+ seats make a nice work table for my tools while working on the AC
  15. #15 Re: Blend Door Actuator or Temp Controls?
    Sep 2011
    Nice little update, I did today the one thing I was trying to avoid, an AC system check and recharge. My system was low, it only had under 1/2 a lb. of freon left. The tech did a recovery, vacuum and pressure test which it passed, then added freon. Now the AC blows Ice Cubes.
    Although the blend door actuator was bad, so replacing that helped. The ac control unit that I got form the JY was bad. I put in the original one back in and all is good. Hope this helps someone later.
  16. #16 Re: Blend Door Actuator or Temp Controls?
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    good work! im gonna pick up driver and passenger mode door actuators and vac pump for mine. mine continues to blo through all vents. i tested vac ball for any leaks, it was good, ran new silicon vac line from ball to line that goes to firewall.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  17. #17 Re: Blend Door Actuator or Temp Controls?
    Sep 2011
    It's gotta be something simple bro, as long as it works though, fvcking TX heats is brutal.
  18. #18 Re: Blend Door Actuator or Temp Controls?
    Mar 2012
    Dallas
    yeah, already getting 90* days, time to get this **** fixed
  19. #19 Re: Blend Door Actuator or Temp Controls?
    Sep 2011
    Tell you what though, I will take heat over cold any day.
  20. #20 Re: Blend Door Actuator or Temp Controls?
    Mar 2012
    Dallas
    True that. I hate the cold.
  1. Blend Door Actuator Replacement
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-02-2017, 04:59 AM
  2. Blend door or actuator?
    By EJOUIE in forum General Tech Discussion
    Last Post: 05-05-2013, 11:00 PM
  3. Blend Door Actuator, my own damn fault
    By chevyy1212 in forum General Tech Discussion
    Last Post: 10-28-2011, 10:54 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
