Sorry to revive this thread, but no need to make a new one. There is a lot of good info in this thread so far, but not the answer I'm looking for.
Problem- Turn on the AC and it blows cold out of the passenger side and luke warm out of the driver side.
MY fixes so far- I replaced the AC control unit (JY unit)
I replaced the driver door actuator (JY unit)
Still does the same thing. Also before when I would select defrost the air would not blow out of defrost vents, after parts it works as should.
The AC compressor is not short cycling and is operating normal.
Should I still get a vacuum put on the system to check for leaks and recharged?
Should I look for another problem?
Here I'm holding my original AC controler new JY installed
Driver Actuator, Original Unit
Driver Actuator, Original Unit other side. Note: The JY unit had a metal rotating piece instead of plastic like the original.
Just for fun side Note: I noticed the 04+ seats make a nice work table for my tools while working on the AC
