Thread: Where to hook up oil pressure & volt gauge
Results 1 to 20 of 26
  1. #1 Where to hook up oil pressure & volt gauge
    Highland Heights, KY
    I wasnt sure if I was to hook up the volt gauge to a hot that comes on when the ignition is turned on or to a hot from the alternator to get true voltage. (i always hooked them up to just anything)
    Also the OIl pressure gauge, i know where to on the back of a v8 but this is a totaly new motor to me.. So where exactly do i hook up my copper tube for the OIL PSI...
    THANKS
  2. #2 Re: Where to hook up oil pressure & volt gauge
    Charles City, IA
    This is what i found. All credit goes to webracin
    "There is a plate that holds the oil filter. On that plate you will find the oil sending unit for the stock system. You can remove the stock sending unit and replace with a sending unit for your guage, OR, get a gasket for the plate, remove the plate and drill and tap a hole next to the original sending unit. You will need a 45 deg elbow so that the sender does not hit the CV axle, but I have been runing mine for over 5 years with no problems."
    webracin
    SMGPFC Two Nipple General
  3. #3 Re: Where to hook up oil pressure & volt gauge
    Jersey
    ^I just removed the stock one. Its really junk anywayz, just goes to a dummy light in the dash and only goes off when you get below 5psi <which is pointless. Now i can accually monitor the pressure.
    16' wrx sti- stock
  4. #4 Re: Where to hook up oil pressure & volt gauge
    Quote Originally Posted by 99prixgt View Post
    The one by the oil filter is the oil pressure switch for the fuel pump, or is that a different one...
  5. #5 Re: Where to hook up oil pressure & volt gauge
    Oklahoma
    Im moving this to the right section this time but I would encourage you to read this:
    http://www.grandprixforums.net/f14/a...read-6828.html
    Post #7. I came very close to deleting this. I cant make the information more available, more plain or anything. Please pay attention to where you are posting and make sure it is in the correct section.
  6. #6 Re: Where to hook up oil pressure & volt gauge
    I apologize i thought i clicked tech for w-body, i may have clicked tech tips...and might i add that im glad you are very patient with those of us who cant read well...LOL. but thank you
    As for stock Oil presure sending unit, do i unscrew it along with the harness, cause im runnng a manual gauge not a electric
    But i found this pic, if I get a few brass elbows and fittings and a T, from work.I can have my oil PSI gauge hooked up with the factory sending unit so the dummy light still works.
    Where to hook up oil pressure &amp; volt gauge Attached Images
  7. #7 Re: Where to hook up oil pressure & volt gauge
    SO i'm going to get my fititings today so if anyone is interested i will post some pics when im done, so maybe if anyone else has a mechanical gauge we could save it for further use...
  8. #8 Re: Where to hook up oil pressure & volt gauge
    Barksdale AFB, LA
    Technically the PCM does monitor actual pressure through the one you removed. Just because you don't have access to that value doesn't mean it doesn't work. My 3.8L has the same sender and my car came stock with a working oil pressure gauge.
    2009 Subaru Impreza WRX STI
  9. #9 Re: Where to hook up oil pressure & volt gauge
    Oklahoma
    The Bonnevilles and the Impalas and I assume others come with a three wire sending unit, the GP only got a two wire sender which as mentioned just basically trips the low oil pressure light on the dash. Why they cheaped out the GP Im not sure.
  10. #10 Re: Where to hook up oil pressure & volt gauge
    Barksdale AFB, LA
    It's seriously different? I can't believe they changed it from a oil pressure sender to a oil pressure switch just for the GP.
  11. #11 Re: Where to hook up oil pressure & volt gauge
    Oklahoma
    They did, Ive had to replace the sender on a Bonnevile before and its a different sender from the GP. I was kinda shocked myself, but thats how it was.
  12. #12 Re: Where to hook up oil pressure & volt gauge
    Barksdale AFB, LA
    I like GM because most of the time I understand why things are the way they are.
    This is an exception.
  13. #13 Re: Where to hook up oil pressure & volt gauge
    Oklahoma
    Yeah, it made no sense to me at all either. The guy brought the car to me and said that his oil pressure gauge was not reading right (my first thought was that he didnt know what gauge he was looking at since the GP didnt have a pressure gauge) and then proceeded to hand me the oil pressure sending unit. I looked at it and told him he had gotten the wrong one. He swore up and down that it was the right one.
    So I crawl up under the car, pull the plug off the sender and sure enough, it was the right one. I checked the dash and sure enough, there is a bona fide oil pressure gauge in the Bonneville. After that point I was mad. Why didnt the GP have one?
    Though, I have thought if it would be possible to run the Bonneville sender and have the dummy light on the dash work as it should on the GP and use the extra wire to run to an after market gauge so that you get the best of both worlds.
    I mean, you arent always looking at the gauge pillar and at least there is some warning on the dash that is functional that would catch your eye.
  14. #14 Re: Where to hook up oil pressure & volt gauge
    Barksdale AFB, LA
    You'd need a gauge calibrated to the PSI and impedance range of the factory sender. I don't know those ratings, unfortunately.
  15. #15 Re: Where to hook up oil pressure & volt gauge
    Oklahoma
    True, but it could be worth the experimenting at least.
  16. #16 Re: Where to hook up oil pressure & volt gauge
    since you guys are on here, what about trans, and oil temp gauges. Are they pointless, usefull or just a reason for more gauges.... I have 1 extra gauge and its a temp. but not sure what to hook it to.
  17. #17 Re: Where to hook up oil pressure & volt gauge
    Barksdale AFB, LA
    Trans temp isn't much good unless you can bury the sender deep inside the transmission where the factory sender is. I just monitor it through the PCM.
  18. #18 Re: Where to hook up oil pressure & volt gauge
    Oh ok. I read it on another thread that they were putting it in the pan. I wasnt sure if it was even useful with a factory trans, unless a shift kit, stall, or any other mods were being used. I bought a tri-pod w/ gauges and it had a temp in it, but i dont want another water temp gauge. Kinda hate to throw out an extra, really.
  19. #19 Re: Where to hook up oil pressure & volt gauge
    Oklahoma
    I personally would like to have both transmission and oil temperature gauges without having to use a scan tool to monitor stuff like the trans temp. However, if I were told I could only do one my first priority would then shift to trans temp because it frequently can get into ranges that cause severe breakdown of the fluid. You want that temp down in the 170* range. Anything over 200* and youre subjecting your fluid to a temperature that will start to break down the fluid and is kinda rough on the trans.
    Now if you run synthetic trans fluid you have a little more cushion but even so its just good all around practice to keep the trans fluid around 170* or so.
    People change the oil frequently enough that temperature stresses there are not as significant typically though they can be. But you dont want the oil temp up too high because it will start to evaporate off the smaller hydrocarbon chains in the oil and cause evaporation boil off. Likewise, you dont want the oil too cool either because then it cannot evaporate out any fuel or moisture contamination which when in excessive amounts can thin the oil out to dangerous levels or cause sludge and varnish build up.
  20. #20 Re: Where to hook up oil pressure & volt gauge
    now were getting in to a trans topic lol. Im getting a try pod for my a-pillar next week, i have a volt and a oil PSI in my hud pod now so i guess i can get another temp, one for the oil and trans. But where at ont the trans, some said pan some said the plug on the top. Also the oil, the pan or in the block.
    Another q that wasnt ansered before was the oil switch/sender or whatever is mounted my the oil filter (they said to use for oil PSI) isnt that the one that is activated when the fuel pump is.
  1. Boost and oil pressure Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:40 AM
  2. Connection of Manual Oil Pressure Gauge
    Last Post: 07-25-2008, 03:47 PM
  3. 12 Volt Remote
    By mainecrab in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2008, 09:45 AM
  4. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
  5. anyone have a Prosport fuel pressure gauge?
    By fst in forum PCM Tuning
    Last Post: 04-02-2008, 06:38 AM
