Thread: Where to hook up oil pressure & volt gauge
Results 1 to 20 of 26
  1. #1 Re: Where to hook up oil pressure & volt gauge
    Charles City, IA
    This is what i found. All credit goes to webracin
    "There is a plate that holds the oil filter. On that plate you will find the oil sending unit for the stock system. You can remove the stock sending unit and replace with a sending unit for your guage, OR, get a gasket for the plate, remove the plate and drill and tap a hole next to the original sending unit. You will need a 45 deg elbow so that the sender does not hit the CV axle, but I have been runing mine for over 5 years with no problems."
    webracin
    SMGPFC Two Nipple General
  2. #2 Re: Where to hook up oil pressure & volt gauge
    Jersey
    ^I just removed the stock one. Its really junk anywayz, just goes to a dummy light in the dash and only goes off when you get below 5psi <which is pointless. Now i can accually monitor the pressure.
    16' wrx sti- stock
  3. #3 Re: Where to hook up oil pressure & volt gauge
    Highland Heights, KY
    Quote Originally Posted by 99prixgt View Post
    The one by the oil filter is the oil pressure switch for the fuel pump, or is that a different one...
  1. Boost and oil pressure Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:40 AM
  2. Connection of Manual Oil Pressure Gauge
    Last Post: 07-25-2008, 03:47 PM
  3. 12 Volt Remote
    By mainecrab in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2008, 09:45 AM
  4. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
  5. anyone have a Prosport fuel pressure gauge?
    By fst in forum PCM Tuning
    Last Post: 04-02-2008, 06:38 AM
