Thread: HVAC upgrade 04+
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 HVAC upgrade 04+
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Tried a search no luck...
    Haven't tried it yet but anyone try putting the digital hvac in a 04+ that is non digital?
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: HVAC upgrade 04+
    Curious myself I need to get my heated seats working again
    04 Comp G.
  3. #3 Re: HVAC upgrade 04+
    If 97-03 cars can't do it, then I still bet the 04+ cars can't.
    Unless you want to rip all the wires out and BCM and whatever else needs to be swapped and somehow install the correct pieces and somehow make it work.
  4. #4 Re: HVAC upgrade 04+
    London Ont, Canada
    i wanna upgrade to one with the heated seat switches.. never thought about the digital ones.
  5. #5 Re: HVAC upgrade 04+
    Oct 2011
    MI
    97-03 have a completely different setup Def not possible.
    04+ have the same size plug as a digital, only thing I could see being a problem is the auto sense portion for heat probably won't work since I know that sensor isn't in the location where it should be. I didn't check for a preexisting factory plug yet though.
  6. #6 Re: HVAC upgrade 04+
    Uh! Figures I got the seats out of a 06 Gxp since I have a 04 its not plug and play. Damn guess ill have to figure out how to wire them up
    04 Comp G.
  7. #7 Re: HVAC upgrade 04+
    Yoga city
    All this needs to be programmed to work in bcm, so say you get all harnesses and such hooked up correctly. You still need to find a willing dealer to install that option
  8. #8 Re: HVAC upgrade 04+
    I think the digital had a 3 plug set up in the back vs the 2 plugs we have in the back of ours.
    04 Comp G.
  9. #9 Re: HVAC upgrade 04+
    Oct 2011
    MI
    Hmm. I could have swore we only had one. Haven't put much thought into it besides saying hey they look purty and we specialize in factory upgrades at work. I think I could figure it out if it's possible.
    I already have heated seats so that's not a concern.
  10. #10 Re: HVAC upgrade 04+
    London Ont, Canada
    it would be so much easier if it were possible to leave the dealer out of it.
    same for the 5button stuff, dealers jsut want too much money and have no clue.
  11. #11 Re: HVAC upgrade 04+
    Oct 2011
    MI
    Too bad your not close Tech2 is a wonderful thing
  12. #12 Re: HVAC upgrade 04+
    Yup finding one that's willing to do it and then not getting raped by the price. Didn't dawn on me how much I missed my heated seats until my back aches and I use the ones in the Silverado.
    04 Comp G.
  13. #13 Re: HVAC upgrade 04+
    Yea IIRC I was looking at buying a digital HVAC awhile back then remembered we had 2 plugs but I could be wrong.
    So since you specialize in that..find out how to do lol. Then how to get 06 seats to work in my 04 yes I have the heated option already.
    04 Comp G.
  14. #14 Re: HVAC upgrade 04+
    Oct 2011
    MI
    I could give you wiring diagram from both years if you want.
    Otherwise we sell aftermarket heated seats that are easy to install and work great. I can probably get you a deal if that's the route you wanted.
  15. #15 Re: HVAC upgrade 04+
    London Ont, Canada
    You can seperate the pads from cusion. No idea how to reglue it LoL
  16. #16 Re: HVAC upgrade 04+
    IIRC they velcro'd on.
    04 Comp G.
  17. #17 Re: HVAC upgrade 04+
    Oct 2011
    MI
    I Install heated seats all the time we don't re glue anything. The seats natural tension is held tight from the factory style clips holding the skin on.
  18. #18 Re: HVAC upgrade 04+
    Oct 2011
    MI
    I'm going to do some research on the two different hvac units and if I get one in the shop I might just swap them out (if possible, plug wise) and see what works. I can program anything I need too with the tech2
  19. #19 Re: HVAC upgrade 04+
    Wiring diagrams would be sweat.
    Don't need the aftermarket heated shears if anything I still got the old wiring/cushion/and heated pads from the old seats still I could just swap all that onto the gxps but trying to avoid having to pull the cushions off as long as I can help it.
    04 Comp G.
  20. #20 Re: HVAC upgrade 04+
    Oct 2011
    MI
    Here's 04 gtp and 06 gxp heat seat circuits. zoom in.
  1. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  2. DIC HVAC gone..
    By Jay7199 in forum General Tech Discussion
    Last Post: 06-07-2011, 10:03 PM
  3. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  4. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
  5. 04 hvac
    By Scott Francis in forum Introductions/Noob Questions
    Last Post: 10-16-2009, 03:36 PM
