I know this is a boring topic but I'm in need of help, desperately.
2007 GT - 89000 miles. Wires came out - with a huge effort and cut hands - plugs came out quite easy and did not break while being removed.
New wires - Autolite, stock. New plugs - Autolite 606 gapped at .060. Small amount of anti-seeze on the plug threads. Plugs went in fairly easy, except for the one I snapped, removed and replaced with another one (obviously). Did not torque to death by any means. New wires went on, with spark plug grease. I have checked the firing order over and over. All connections secure.
When it starts, it start strong and about a second after, sounds like death. Roughest idle - surging - running rich - gets close to dying then sputters back to life...checked firing order again - everything fine - etc etc. Each cylinder is hot after running - but it's running rich.
What am I missing - could I have cracked a plug putting them in? Bad wires??
I have the old plugs - and am thinking about putting them back in and seeing if this fixes it. Is copper a problem? Everyone here says they're the best to run.
Thank you for anything and everything.
Warren
