word of adivice not sure if anyone seen this but i will post all info i can obtain,
Actuator Recalibration When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:
Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
- Place the ignition switch to the OFF position.
- Disconnect the scan tool.
- Install the HVAC control module.
- Connect all previously disconnected components.
- Start the vehicle.
- Wait 40 seconds for the HVAC control module to self-calibrate.
- Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:
Preferred Method (w/Scan Tool)
- Clear all DTCs.
- Place the ignition switch in the OFF position.
- Install the HVAC actuator.
- With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Alternate Method (w/o Scan Tool)
- Clear all DTCs.
- Remove the HVAC/ECAS fuse for a minimum of 10 seconds.
- Install the HVAC/ECAS fuse.
