Thread: Pan drop and filter change.
Results 1 to 10 of 10
Bluemagic Pan drop and filter change. 04-04-2013, 06:36 AM
DirtDog Re: Pan drop and filter... 04-04-2013, 08:00 AM
Bluemagic Re: Pan drop and filter... 04-04-2013, 08:11 AM
Bluemagic Re: Pan drop and filter... 04-04-2013, 11:49 AM
Fivefingerdeathpunch Re: Pan drop and filter... 04-04-2013, 12:18 PM
Bluemagic Re: Pan drop and filter... 04-04-2013, 12:28 PM
BillBoost37 Re: Pan drop and filter... 04-04-2013, 12:34 PM
Bluemagic Re: Pan drop and filter... 04-04-2013, 12:36 PM
BillBoost37 Re: Pan drop and filter... 04-04-2013, 12:54 PM
Bluemagic Re: Pan drop and filter... 04-04-2013, 02:43 PM
  1. #1 Pan drop and filter change.
    Dec 2010
    DMV
    Ok today im going to drop my pan and change the filter. Hopefully this will fix my whining trans pump. Anything other tips I should b aware of before I start? The trans has maybe 20,000 miles on it but the whine is scaring me lol.
    Also where are the cooler lines located? Someone told me that the lines could b on backwards so that's why the pump is starving for fluid. True? Not true?
  2. #2 Re: Pan drop and filter change.
    I live here. DirtDog's Avatar
    Jun 2012
    Dropping the pan and changing the filter is an easy task. Just don't force the new filter in...it should slide easily. The lines for the tranny cooler are located on drivers side. If u jack the car up and lay under it on drivers side there is two lines coming from tranny. Or u could also follow them from the radiator back to the tranny.
  3. #3 Re: Pan drop and filter change.
    Dec 2010
    DMV
    Thanks! I'll post back with results
  4. #4 Re: Pan drop and filter change.
    Dec 2010
    DMV
    Everything went smoothly but I barely see any fluid on the dipstick. I put 6 qts in. Any ideas? No leaks either.
  5. #5 Re: Pan drop and filter change.
    You didnt put enough in, you need atleast 7.5 to 8 quarts.
  6. #6 Re: Pan drop and filter change.
    Dec 2010
    DMV
    Ok great. Thanks!
  7. #7 Re: Pan drop and filter change.
    A filter is not suppsed to slide in easily. Read the info on the sheet of paper that comes in the kit. That filter is supposed to be snug and hold itself up w/o issues. A loose filter means the pump can pull air around the filter neck.
  8. #8 Re: Pan drop and filter change.
    Dec 2010
    DMV
    Yea I had to really bang it in there.
  9. #9 Re: Pan drop and filter change.
    Gently tap is more like it...lol
  10. #10 Re: Pan drop and filter change.
    Dec 2010
    DMV
    Lol.
  1. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  2. How much Fluid for Trans Filter Change
    By dhdolphns in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2011, 03:48 PM
  3. advice on tranny pan drop/filter change-trannyman?
    By Liquifire in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2009, 11:45 PM
