Thread: It's about time I find the whine.
Results 1 to 20 of 23
  1. #1 It's about time I find the whine.
    Dec 2010
    DMV
    That's coming from my engine bay on cold startups lol. A little info, power steering pump is on its way out. It leaks so I keep refilling it when it gets low. After a while it goes away but today I noticed it make the noise while it was warm and when I made a left turn. It's really loud on the drivers side wheel. I noticed that when I bent down to grab my keys that had fallen down by the right wheel. (can't say it's louder than the passengers side because I didn't get a chance to check it out.)
    I cycled through the gears and no sound in neutral or park but a slight noise that goes away in a few secs BUT noise was constant when it put the car in 1st.
    Trans has less that 20,000 miles on it after fresh rebuild and warranty is expired of course.
    I also noticed that my supercharger pulley looked a but wobbly while spinning so either it's not on right or snug or maybe a pulley is going out?
    Could it be my ac compressor? Lately I noticed that my air doesn't work when I turn it on (hoping it needs freon).
    Thanks in advance guys.
  2. #2 Re: It's about time I find the whine.
    Dec 2010
    DMV
    Any ideas? Anyone? I confirmed that its coming from the drivers side. What else is over there besides the trans?
  3. #3 Re: It's about time I find the whine.
    Cambridge, Ontario Canada
    Being on the drivers side seems strange, aside from some internal trans parts, most of the moving parts that could cause a whine would be on passenger side. Did you check trans fluid?
    2005 E55 - stock
  4. #4 Re: It's about time I find the whine.
    Dec 2010
    DMV
    Yes I checked it and it seemed normal. Pink and at the max operating line on the dipstick. Should I try to check it again?
  5. #5 Re: It's about time I find the whine.
    Banned
    Jan 2013
    maryland
    Being this was the same situation with my gtp i can attest to this.. For me it was the by the axle and rack and pinion that made the whine because of a leak that leak can be anywhere you might want to put it in the air and find the location where it is most making that whine sound at because changing the fluid every 5 days just gets annoying best of luck bruh
    Sent from my SGH-T989 using Tapatalk 2
  6. #6 Re: It's about time I find the whine.
    Dec 2010
    DMV
    Damn. Well atleast it's not the trans lls. I will take it to the shop to get it looked at. I mean it goes away when it warms up but I'm guessing its a matter of time before its a every day thing.
  7. #7 Re: It's about time I find the whine.
    Can you take video of "whine"? Does it vary with rpm?
    2005 E55 - stock
  8. #8 Re: It's about time I find the whine.
    Dec 2010
    DMV
    No the whine doesn't get louder with acceleration. It actually goes away after awhile. I can get a vid up in a few
  9. #9 Re: It's about time I find the whine.
    Dec 2010
    DMV
  10. #10 Re: It's about time I find the whine.
    Dec 2010
    DMV
    There's the two vids. One is by the drivers side wheel and the other Is while shifting through gears
  11. #11 Re: It's about time I find the whine.
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    my car does that whe nits cold i amounted it to fluid level
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  12. #12 Re: It's about time I find the whine.
    Dec 2010
    DMV
    Did adding fluid eliminate the sound?
  13. #13 Re: It's about time I find the whine.
    Sep 2012
    bridgeport,NY
    nope the cooler lines were hooked up backwards causing the fluid to not flow well so the pump started to whine
  14. #14 Re: It's about time I find the whine.
    Dec 2010
    DMV
    So reversing the lines fixed the problem?
  15. #15 Re: It's about time I find the whine.
    Dec 2010
    DMV
    But I've never heard the whine before its cold. So that is what's confusing me
  16. #16 Re: It's about time I find the whine.
    Sep 2012
    bridgeport,NY
    do any rad or trans work lately
  17. #17 Re: It's about time I find the whine.
    Dec 2010
    DMV
    None. That trans has been in the car for 20,000 miles.
  18. #18 Re: It's about time I find the whine.
    Sep 2012
    bridgeport,NY
    check the lines and make sure they are hooked up right i didnt get a whine till it got cold too
  19. #19 Re: It's about time I find the whine.
    Dec 2010
    DMV
    Ok thanks. Any tips on how they should be hooked up? I have no idea how they should look
  20. #20 Re: It's about time I find the whine.
    Sep 2012
    bridgeport,NY
    on the rad the top fiting is feed
  1. First Time hearing the whine
    By klj5022 in forum Track Sessions and Kills
    Last Post: 06-02-2010, 08:35 AM
  2. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  3. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  4. Whine - time to change SC oil? or too late?
    By nirahlee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2009, 08:14 PM
