Thread: New prix comes with problems..key lock..Oil pan bolt...
Results 1 to 7 of 7
Threaded View
chicagochuck New prix comes with... 04-03-2013, 08:16 PM
Matt Palm Re: New prix comes with... 04-03-2013, 08:17 PM
DirtDog Re: New prix comes with... 04-03-2013, 08:34 PM
chicagochuck Re: New prix comes with... 04-03-2013, 09:35 PM
Fivefingerdeathpunch Re: New prix comes with... 04-03-2013, 08:36 PM
JaredR215 Re: New prix comes with... 04-04-2013, 06:10 PM
Scottydoggs Re: New prix comes with... 04-04-2013, 06:41 PM
  1. #1 New prix comes with problems..key lock..Oil pan bolt...
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    My buddy bought a 01 grand prix 100,000 3100 motor
    About a week ago the key would not turn in the cylinder..The tumbler is stuck It cannot be turned backwards or forward to start the car. Eventually it worked after messing with it. But it did it again today and She couldn't even get the car home.
    I have read around about the key getting stuck in the ignition and the key not turning to the off position, but this one is the tumbler is stuck in the off position as if its the wrong key, or as if the steering wheel is locked which neither is the case. ......She only got one key with the car.
    Secondly the oil pan screw can be loosened but will not come out of the pan completely.. I could possibly yank it out but wanted to make sure I had a solution to get a bolt back in, or would a whole new pan be the only remedy? oversize plug?
  1. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  2. 2008 Grand Prix Door Lock Issue
    By 2008GrandPrix in forum General Tech Discussion
    Last Post: 03-27-2012, 05:03 PM
  3. problems removing crank bolt from hub
    By BonesSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2010, 07:50 PM
  4. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
