Thread: New prix comes with problems..key lock..Oil pan bolt...
Results 1 to 7 of 7
  1. #1 New prix comes with problems..key lock..Oil pan bolt...
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    My buddy bought a 01 grand prix 100,000 3100 motor
    About a week ago the key would not turn in the cylinder..The tumbler is stuck It cannot be turned backwards or forward to start the car. Eventually it worked after messing with it. But it did it again today and She couldn't even get the car home.
    I have read around about the key getting stuck in the ignition and the key not turning to the off position, but this one is the tumbler is stuck in the off position as if its the wrong key, or as if the steering wheel is locked which neither is the case. ......She only got one key with the car.
    Secondly the oil pan screw can be loosened but will not come out of the pan completely.. I could possibly yank it out but wanted to make sure I had a solution to get a bolt back in, or would a whole new pan be the only remedy? oversize plug?
  2. #2 Re: New prix comes with problems..key lock..Oil pan bolt...
    antioch ill
    i might be wrong but they only came with 3.1 or 3.8
  3. #3 Re: New prix comes with problems..key lock..Oil pan bolt...
    I live here. DirtDog's Avatar
    Jun 2012
    For the oil pan I had that problem with my 04gp I used to have and I pulled the plug out...well let's just say it didn't go back in and I had to replace the oil pan. On the 3.8 motors its a pita I dunno on the 3.4 how hard it is. I can copy and paste some info from the gm repair manuals for u if ya want
  4. #4 Re: New prix comes with problems..key lock..Oil pan bolt...
    No 3.4 motors on 97+ grand prix's.
  5. #5 Re: New prix comes with problems..key lock..Oil pan bolt...
    Aug 2012
    Chicago
    Sorry motor is a 3100
    Quote Originally Posted by marines542 View Post
    That's why I didn't just yank it out, if anything, Ill have shop see what they can do. At-least It will already be there.
    Yeah I have had quotes for 3800 and 3100 most shops charge about $400.00. to remove oil pan.
    any ideas as far as the key?
  6. #6 Re: New prix comes with problems..key lock..Oil pan bolt...
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    On the key issue, make sure it's not a worn out key. When I bought my 98 the key was worn down and I had to jiggle it back and forth to get the ignition to turn. I got another key made and problem solved.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  7. #7 Re: New prix comes with problems..key lock..Oil pan bolt...
    you can try graphite lock spray, it makes locks slick as sh-it.
    sprat the lock, and the key work it in and out a few times, then try to work it forward and back.
    if this fails, the ignition tumbler is shot.
  1. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  2. 2008 Grand Prix Door Lock Issue
    By 2008GrandPrix in forum General Tech Discussion
    Last Post: 03-27-2012, 05:03 PM
  3. problems removing crank bolt from hub
    By BonesSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2010, 07:50 PM
  4. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
