Thread: Intake leak? weird noise at start up
Results 1 to 9 of 9
Threaded View
chevy350 Intake leak? weird noise at... 03-31-2013, 10:55 PM
Scottydoggs Re: Intake leak? weird noise... 04-01-2013, 12:12 AM
chevy350 Re: Intake leak? weird noise... 04-01-2013, 12:39 AM
Fivefingerdeathpunch Re: Intake leak? weird noise... 04-01-2013, 12:45 AM
chevy350 Re: Intake leak? weird noise... 04-01-2013, 01:01 AM
BillBoost37 Re: Intake leak? weird noise... 04-02-2013, 10:08 AM
chevy350 Re: Intake leak? weird noise... 04-02-2013, 11:51 PM
jlgp2007nc Re: Intake leak? weird noise... 04-03-2013, 06:55 AM
chevy350 Re: Intake leak? weird noise... 04-03-2013, 07:34 PM
  1. #1 Intake leak? weird noise at start up
    Sep 2012
    Dealership
    I went ahead and changed my lower intake gaskets. When I take the oil cap off the engine will stumble and die, also when I pull out the dipstick it will stumble a bit and you can feel it sucking air in... Iv noticed when I manipulate the oil cap the noise will coincide with it. I took off serp belt and the noise was still there I initially thought it could be the power steering pump.
    I changed upper gasket and pcv valve as well I also changed the larger o ring that sat at the top of the pcv housing.
    I have found a thread on here saying possibly pcv..so before I go messing with it..How simple as it may seem I want to make sure what I have to do
    This may sound stupid but as far as that little pipe or plastic hose that's attached to the upper intake gasket...
    When I took off the upper plenum the plastic pipe with the curve at the end was just sitting there in its brackets, it was totally the opposite of how the new one came in its package..so I lined up the curve end with the pcv port.... Not sure if that was correct...
    Do I need another pcv or maybe change that spring..I'm hoping its that simple.
    engine squeal.... - YouTube
  1. Another weird coolant leak
    By 04silverprix in forum General Tech Discussion
    Last Post: 05-08-2012, 06:51 AM
  2. Weird noise on take off, after first start
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 05:17 AM
  3. Weird noise at cold start.
    By WolvesSoulZ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2012, 05:36 PM
  4. Weird leak..
    By bowsox88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2011, 03:40 PM
  5. Weird Part and a coolant leak from it
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2008, 05:42 PM
