Thread: Weird leak..
Results 1 to 15 of 15
  1. #1 Weird leak..
    SE Level Member bowsox88's Avatar
    indiana
    In the last month or so i have replaced bolth valve cover gaskets, lower intake gasket,upper intake manifold and gasket and bolth plastic coolant elbows. Now i have a water/black oil mix leak under the center of the engine, i changed my oil last week after the lower intake gasket change so my oil is clean, so its weird the oil from the leak is black. Just a little confused, but anyone have any ideas? Also i dont see any fluid anywhere that i can see on the top or sides of the engine.
  2. #2 Re: Weird leak..
    Omaha, NE
    How are your fluid levels? Do they drop or stay the same?
  3. #3 Re: Weird leak..
    indiana
    Oil is steady and coolant was a little low after work today.
  4. #4 Re: Weird leak..
    Omaha, NE
    Have you made sure all your hose clamps are tight?
    Coolant tends to gunk up and catch dirt when it leaks, especially dexcool after its exposed to air.
  5. #5 Re: Weird leak..
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    have u checked around the heads?
  6. #6 Re: Weird leak..
    indiana
    Quote Originally Posted by BoostnBlackGTP View Post
    Front head yes rear cant see i have never tilted an engine forward so is that the only want to really check it?
  7. #7 Re: Weird leak..
    Waterloo, Iowa
    u can look from underneath. It could be your headgasket seaping..
  8. #8 Re: Weird leak..
    indiana
    Ok thanks will take a look.
  9. #9 Re: Weird leak..
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    X2..
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  10. #10 Re: Weird leak..
    indiana
    OK i found where my leak is coming from i noticed it is coming from a tube sticking out of the firewall on the passenger side and on the end of this tube is a rubber elbow that flattens out on the end and has a small hole at the tip of this elbow I'm guess it has something to do with the heater but why is it leaking this water all of a sudden? Any help would be great thanks.
  11. #11 Re: Weird leak..
    Jun 2010
    Hampton, VA
    Air conditioning condensate drain. If your heater core is leaking, it will drain from the same tube.
  12. #12 Re: Weird leak..
    indiana
    Ok so if its my heater core how hard are thoses to replace? Im not running A/C so it would have to be the heater core i would assume.
  13. #13 Re: Weird leak..
    Akron Ohio
  14. #14 Re: Weird leak..
    Please..don't think this is the most uncommon part on the car, a headgasket. I would money down on a bet against BoostedBlack that it isnt' a headgasket.
    My first thought halfway through reading your post was that you cleaned the LIM bolts and didnt' put any sealant on them for reinstallation.
  15. #15 Re: Weird leak..
    indiana
    I drove home yesterday without the heat on and had no water leaking so im gonna try having the heat on but not on defrost....anyway is this a normal thing to have water dripping out of this hose from the firewall i know car do this when the AC has been running.
  1. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  2. weird DTC...
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-17-2010, 12:33 AM
  3. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
  4. weird....
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-24-2010, 12:30 AM
  5. Weird Part and a coolant leak from it
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2008, 05:42 PM
