Thread: I got P0107 low lean.. what should I do?
Results 1 to 17 of 17
  1. #1 Re: I got P0107 low lean.. what should I do?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    have you even put a vacuum gauge on the car, your looking for a leak when you dont know if you have a leak.........
    check vacuum source to map with gauge, vacuum line could be restricted, try running a different line to map
    then i would check sensor ground, 5v ref, signal circuit for open/short
    edit: also a p0107 means (Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage)
    this does not allways mean car is lean
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. p0107 and p0171
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2013, 11:49 AM
  2. lean
    By illy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2012, 07:40 AM
  3. How to lean a car out with DHP
    By dsmuts in forum PCM Tuning
    Last Post: 07-12-2012, 10:18 PM
  4. P0107
    By mdkoh in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2011, 11:46 AM
  5. 940 WOT o2 is lean?
    By Bio248 in forum PCM Tuning
    Last Post: 03-04-2008, 05:55 PM
