Thread: Carpet very wet on drivers side floor
Results 1 to 20 of 20
  1. #1 Carpet very wet on drivers side floor
    Oct 2008
    NY
    Hey guys, need some help. Every time it rains hard the drivers side floor gets completely soaked. I've opened my door to a puddle of water sitting in the drivers side. Usually about 2 inches of water sitting there. I have no idea where its coming from and dont know what to do. Any help would be appreciated, thanks
  2. #2 Re: Carpet very wet on drivers side floor
    Oklahoma
  3. #3 Re: Carpet very wet on drivers side floor
    Oct 2008
    NY
    They only talk about passenger side not the driver side.
  4. #4 Re: Carpet very wet on drivers side floor
    Odessa, MO
    Quote Originally Posted by magician1979 View Post
    Yeah, I've never seen the deflector problem get the driver's side wet. The deflector problem causes water to pour directly into the blower housing and it leaks out the housing on the inside effectively soaking the passenger side. Since it's your driver's side suffering, I'm sure the deflector is not the problem. Unfortunately, I'm afraid you may have some other problem and I'm not sure which direction to steer you in on this one to help you solve it.
  5. #5 Re: Carpet very wet on drivers side floor
    chi-town
    hopefully you dont have the same problem i do causing water on my driver side carpet. the roof is rotted and rusted away under the rubber seal around the windshield. roof looks perfect till you lift the black seal around the windshield , lotsa rust under there on mine. upside is this gives me a reason to pick up a gtp
  6. #6 Re: Carpet very wet on drivers side floor
    Apr 2008
    Chillin at the Beach , VA
    Close the window. JK, had to try and throw a little humor in there. Not sure what would cause the driverside to leak. I have always hear of the pass side. Do you have a sunroof? Headliner wet any? If you have a sun roof, that could be leaking and the water running down the a piller to the floor.
  7. #7 Re: Carpet very wet on drivers side floor
    Oklahoma
    Crap, I completely blanked out the water was coming in on the drivers side. My bad.
  8. #8 Re: Carpet very wet on drivers side floor
    Moore, Oklahoma
    Check yiour body plug/gromment on the floorboard directly under the car
    Shawn W. Larsen
  9. #9 Re: Carpet very wet on drivers side floor
    chi-town
    i was able to sit in my car and watch the water drip (sometimes stream) right out of the corner of the dash , onto the parking brake pedal then onto the floor.
  10. #10 Re: Carpet very wet on drivers side floor
    Odessa, MO
    Sounds like a windshield leak. I would pull your a-piller trim off and possibly the driver's sun visor so you can pull the headliner down just a little. You should be able to see the urethane adhesive that glues in the windshield by looking in between the glass and pinchweld from the inside. While keeping an eye on that, have someone run water on the top corner of the glass and watch for leaks all the way down that side.
    Sounds like that is the problem and it is running down the a-piller and dripping down by the e-brake pedal. When you find it, you should be able to get a tube of automotive urethane at the parts store and seal it from the inside, then water test again and replace your trim.
  11. #11 Re: Carpet very wet on drivers side floor
    Oct 2008
    NY
    I'll give it a shot tomorrow during lunch. Thanks for the help. I'll let you know what I find
  12. #12 Re: Carpet very wet on drivers side floor
    SE Level Member rfmgtp02's Avatar
    Oct 2008
    Voorhees NJ
    I just discovered this exact problem in my car this morning. Drivers side is completely drenched. literally looks like someone poured a gallon of water under my floor mat and then put the mat on top. The mat wasnt wet on top and there was no wetness anywhere else that would help point towards a leak. It has been raining since yesterday afternoon. I was also driving for almost 2 hours yesterday in the rain and saw nothing to indicate a leak during my drive home. It also only wet in the very bottom of the floor board where the mat would lay, nothing on any of the "humps" coming up. Im lost on this one. Could definately use some advice.
    EDIT: Just saw this thread is in the engine section for some reason. Could this be moved to a more appropriate area?
    2002 GTP 2DR Red Fire Metallic
  13. #13 Re: Carpet very wet on drivers side floor
    SE Level Member Dangerous313KidInAPrix's Avatar
    Feb 2009
    Detroit, MI
    Same problem here and lookinq for help
    01' Grand Prix SE. Completely all stock besides a JVC CD Unit. Mods coming soon! Also available on MIGPC.com
    R.I.P. 99' Ford Contour SE
  14. #14 Re: Carpet very wet on drivers side floor
    houston
    We have a 2007 Grand Prix and have the same problems. Severe leak on driver's side somewhere high up under the dash. I have removed the cowl panel and everything looks good under there. This thread just ends... did someone find the fix?
  15. #15 Re: Carpet very wet on drivers side floor
    Wausau, WI
    I know that on mine the windshield was replaced by former owner and not sealed properly. I have to get my windshield re-sealed by a professional. If any of you can hear any wind noise while going fast with the windows rolled up all the way, there is a good chance that it is a bad seal somewhere along the windshield. Also as mentioned above it could be coming in through the sunroof if that seal leaks at all. There are water channels(one on each front corner on mine) that can get clogged. I checked that mine or OK as I dumped some water in each corner and made sure that it drained properly. I know mine is not visible unless watching it run down from inside of the trim and out into the floorboard, but all leak locations may be different. 90% or better chance that it is the windshield leaking or sunroof if you have one.
  16. #16 Re: Carpet very wet on drivers side floor
    houston
    Thanks for the info. But we don't have a sunroof. Of course it could be the windshield leaking, put I removed the pillar cover and can see where the windshield and frame meet and there is no water coming in there that I can see. It remains a real mystery. I can pour water all over the cowling area below the wipers and get no water in.
  17. #17 Re: Carpet very wet on drivers side floor
    Wausau, WI
    you are not going to be able to see a hairline crack in the windshield gasket material. I would bet that it is coming through the windshield unless you have a major rust issue going on somewhere.
  18. #18 Re: Carpet very wet on drivers side floor
    houston
    Probably right.
    So what I'll do (as soon as it quits raining) is pull off the rubber seal around the windshield and try to force some RTV into that space then replace the seal while it is not yet cured. Any recommendation for a sealant other than RTV?
    Hopefully that will work, if not I guess the windshield will need to be pulled?
  19. #19 Re: Carpet very wet on drivers side floor
    houston
    Liquifire, is that 167 MPH being clocked on your GTP?
  20. #20 Re: Carpet very wet on drivers side floor
    Wausau, WI
    Well, I am not sure what sealant to use other than RTV. If that still doesnt work, I would personally pull the headliner and A pillars to make sure that is where it is leaking from. If you want to see where about the leak is and you have an air hose hooked up to a compresser, take soapy water and rub it around on the outside of the seal. Take the air hose and spray it with air all around the windshield or where you think you may have a leak. The air will follow the leaks out and blow bubbles or atleast move it around so that you can see where the leaks are at. And, no, that is not my GTP being clocked. Good luck...
  1. Where can I get some black carpet
    By robahr24 in forum Visual/Body Modifications
    Last Post: 08-21-2008, 06:20 AM
  2. Ac dripping into passenger side floor.
    By azzkikr1957 in forum General Tech Discussion
    Last Post: 06-15-2008, 10:24 AM
  3. New carpet and padding
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 05-14-2008, 09:10 PM
  4. New Carpet...
    By drunknmunky in forum Visual/Body Modifications
    Last Post: 04-24-2008, 03:13 PM
