you are not going to be able to see a hairline crack in the windshield gasket material. I would bet that it is coming through the windshield unless you have a major rust issue going on somewhere.
Probably right.
So what I'll do (as soon as it quits raining) is pull off the rubber seal around the windshield and try to force some RTV into that space then replace the seal while it is not yet cured. Any recommendation for a sealant other than RTV?
Hopefully that will work, if not I guess the windshield will need to be pulled?
Liquifire, is that 167 MPH being clocked on your GTP?
