and just where does one find blocks of polly? thats a cool looking mount.
id think a drilled hole and a sleeve in it for a threaded rod, then fat washers and just bolt it from both sides would be rock solid. never have to worry about the studs pulling out. that maybe to tight tho.
That would be ideal and I would've just ran bolts straight through however their slightly offset on the top side and by slightly I mean half a bolt over so close. So I will slot the top bracket a little with a dremel and run it straight through next time with a sleeve for good measure. But this was a great project this block of 95a wasn't much I'm going to see if I can get more if I can I'll chop it myself and sell it for a decent price but it would be on you guys to slot your transmission mount
