Thread: 2004 Grand Prix Cuts Out While Driving
Results 1 to 20 of 20
  1. #1 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    Hello Everyone!
    Got another issue with my 2004 Grand Prix GT2......300k Highway Miles runs like a dream, until recently.
    I will be driving down the road and it could take anywhere between 5 minutes and 10 minutes but the car will just shut off. The first time it wanted to shut off I kind of prevented it from shutting off by giving it a little gas but now It wont stall or "choke", it just seems like power is gone. No certain speed at all, just driving normally and it will just shut off. I will restart it and go on my way but will shut off after a few minutes, its a repetitive cycle. Can anyone help me on this??? It has happen 4 times already twice tonight and twice yesterday, its pretty dangerous especially when not wanted it to happen at high speeds.
    I have looked into it on different forums and I have read it could be : Fuel Pump/ Crankshaft Position Sensor/ MAF Sensor/ Dirty Throttle Body.....the list goes on and on.
    Recent Work that I have done most likely have nothing to do with this problem : Water Pump Replacement/ New Battery/ Coolant Flush and Fill and a new thermostat. When doing the water pump I did remove the big fuse box that is under the hood to get out of my way, but made sure I put it back together when done. All the work was done 3 weeks ago, but this problem just happened.
    If someone can help me eliminate some of the listed "Fixes" without buying the parts just yet I would greatly be thankful!
    Thanks Guys
    Paul
  2. #2 Re: 2004 Grand Prix Cuts Out While Driving
    With that mileage, I suggest a basic tune-up.
    Like...everything.
  3. #3 Re: 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    Tune Up was done about 800 miles ago...I tune it up every 50k miles........
  4. #4 Re: 2004 Grand Prix Cuts Out While Driving
    Alternator dying?
    Possibility.
    Clean the TB and MAF, pretty simple, basically cheapest thing you can do.
    Test the pressure at the rail for the pump...I think these cars sit around 45~psi...if it starts to bleed off, then that ain't good.
    Try that.
  5. #5 Re: 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    Will do, first thing in the morning I will take off the TB spray it down clean it nice, I will also clean the MAF...any special things I must to when cleaning MAF? Recommend anything?
  6. #6 Re: 2004 Grand Prix Cuts Out While Driving
    Electrical parts cleaner, that's it.
  7. #7 Re: 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    Will follow up tomorrow thanks
  8. #8 Re: 2004 Grand Prix Cuts Out While Driving
    Houston
    Does your tach quit working right before it stalls? Sounds like the infamous Crank position sensor. And it rarely throws a SES light or code. Mine finally did after a month of doing that crap. That was back in 2001, before all these forums, so it was fun to track down the problem.
  9. #9 Re: 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    Keith, thanks for the response!...I will drive it around the subdivision tomorrow and play close attention to the tach, if the tach drops down to zero before the stall, should i just go ahead and replace the Crack Pos Sensor?
  10. #10 Re: 2004 Grand Prix Cuts Out While Driving
    GT Level Member Toms04compg's Avatar
    Michigan
    Bad or loose battery connection?
  11. #11 Re: 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    One of the first things I checked.......
  12. #12 Re: 2004 Grand Prix Cuts Out While Driving
    Michigan
    When it runs does it run good like no chugging hesitation ect?
  13. #13 Re: 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    Runs perfect until it cuts out......the first time it hesitated, but now its just like someone turned off the ignition....just dies.
  14. #14 Re: 2004 Grand Prix Cuts Out While Driving
    Michigan
    Bro from the way it sounds it most likely is the CPS ... have your battery checked also if its old especially ...
  15. #15 Re: 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    I just watched a video on replacing the CPS......I don't even have the tool to pull of the balancer, this is not good HA!
  16. #16 Re: 2004 Grand Prix Cuts Out While Driving
    Michigan
    Easy just rent it from orielly or auto zone... its not that bad. Take off tire and splash shield.
  17. #17 Re: 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    Will do, thanks for all your help guys.
    I will update in a day or two when have it figured it out
  18. #18 Re: 2004 Grand Prix Cuts Out While Driving
    Michigan
    I did the same but it was to replace my balance. Its not bad
  19. #19 Re: 2004 Grand Prix Cuts Out While Driving
    Jan 2013
    Detroit
    Drove the dang car around for an hour today....couldn't get it to shut off.
    I have my TB and MAF sensor cleaner ready. I also have my fuel pump pressure gauge ready and went out and purchased a CSP sensor from AutoZone (Duralast) on hand.....They also let me borrow the puller.
    I will keep all the Pontiac guys out there updated as soon as I figure it out....
  20. #20 Re: 2004 Grand Prix Cuts Out While Driving
    Houston
    It's your Crank sensor. I remember when mine did that....I'd drive 10 minutes and boom, Im throwing it in neutral trying to restart it while rolling. Throw a mechanic in the passenger seat and try to replicate, runs great. Those sensors have a sixth sense, I swear to god.
  1. Grand Prix stalls while driving
    By PokerBlakeB in forum General Tech Discussion
    Last Post: 03-02-2013, 09:47 PM
  2. Replies: 7
    Last Post: 06-25-2012, 03:34 PM
  3. 04 grand prix gt2 cuts off while driving?
    By shuttle in forum General Grand Prix Discussion
    Last Post: 02-16-2012, 02:16 PM
  4. 2004 grand Prix shut off while driving
    By Roman in forum General Tech Discussion
    Last Post: 10-24-2011, 09:59 AM
  5. Replies: 8
    Last Post: 01-24-2010, 02:53 AM
