If after you get done with a drive around the block you have a cat that is glowing red then it is clogged. You can take it out (but for off-road use only)but just make sure to plug the rear o2 in with a spark-plug non-fouler threaded in before it otherwise you'll keep throwing p420, which is a cat efficiency code which indicates a clogged cat or a bad rear-o2.
