Thread: How can i check my catilyc convertor to see if its clogging up?
Results 1 to 10 of 10
  1. #1 How can i check my catilyc convertor to see if its clogging up?
    SE Level Member Gchronic's Avatar
    Dec 2012
    Columbia Missouri
    It has no power. it acts like it doesnt wanna shift after 3rd and wrps to 3 grand and the tach flutters. Could this be a position control sesor? that has already been changed almost 2 yrs ago. any and all comments are greatly appreciated. Gary
  2. #2 Re: How can i check my catilyc convertor to see if its clogging up?
    GT Level Member PontiacL32's Avatar
    Sep 2012
    Murray, ky
    Not sure about the sensor, but you can take out your front o2 sensor and see if that fixs anything. If your problem go's away with it out then your cat is clogged.
    Also is your check engine light on?
    2005 Grand Prix GTP, 170,000 miles. Speed daddy headers with no cat, cone intake, MSD wires, flipped dog bones, transgo shift kit FOR SALE.
    2004 GTO six speed, stock for now.
  3. #3 Re: How can i check my catilyc convertor to see if its clogging up?
    take it out for a drive at night, spirited some. then pull over and see if its glowing red. if so its clogged.
    you can also get it up on some car ramps, or jack it up, and when its cold, hit the cat and listen for stuff rattling around inside. if so its also shot.
  4. #4 Re: How can i check my catilyc convertor to see if its clogging up?
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    can you get any issues with no cat?
  5. #5 Re: How can i check my catilyc convertor to see if its clogging up?
    Dec 2012
    Columbia Missouri
    This has been hooked up to a good scanner and the code for the o2 was on it but it was changed and its still doing the same thing. Its at the shop now. i hope he can find out the problem because i cant continue to dump money in this and not fixing the problem
    Gchronic
  6. #6 Re: How can i check my catilyc convertor to see if its clogging up?
    Dec 2012
    Columbia Missouri
    yea theres a Sensor 2 bank 2 after the converter so theres no bypassing it
    Gchronic
  7. #7 Re: How can i check my catilyc convertor to see if its clogging up?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Does it not shift into overdrive at all? May be a transmission issue you are facing.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  8. #8 Re: How can i check my catilyc convertor to see if its clogging up?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    what code did you pull p0420 ??
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  9. #9 Re: How can i check my catilyc convertor to see if its clogging up?
    Nov 2011
    Omaha, NE
    Whenever I wanted to check for a clogged cat I would just disconnect the exhaust right before it and if it drove better (or sometimes would run better) then it was a pretty good indication. However to be safe I would button it back up in front of it and then open it behind it.....if it still ran fine with it disconnected after the cat you would know the cat was fine and the problem was elsewhere. Sometimes it would be animals in the mufflers and other things of that nature.
  10. #10 Re: How can i check my catilyc convertor to see if its clogging up?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    If after you get done with a drive around the block you have a cat that is glowing red then it is clogged. You can take it out (but for off-road use only) but just make sure to plug the rear o2 in with a spark-plug non-fouler threaded in before it otherwise you'll keep throwing p420, which is a cat efficiency code which indicates a clogged cat or a bad rear-o2.
  1. nee catalytic convertor ?
    By circa09 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2012, 04:49 PM
  2. Gutting the convertor
    By BlackCompg04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2012, 09:15 PM
  3. Torque Convertor Messing up.
    By 1997GSX in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-08-2010, 09:58 PM
  4. What aftermarket convertor do you run?
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-03-2008, 12:20 PM
