Thread: Cold problem?
Results 1 to 13 of 13
  1. #1 Cold problem?
    GT Level Member PontiacL32's Avatar
    Sep 2012
    Murray, ky
    In the mornings its about 15-20* and I ususally start the car 10 min before i leave, it will start right up and idle pretty normal but with a mis every once in awhile. Heres the real problem, it seems to be low on power and causing the trans to stay in first longer than normal. Also idle rough in gear, but you can restart it and it all be back to normal except for a miss while idling in gear but go's away as soon as you take off. It mainly happens in the morning but has happened a few times after work, any idea what it could be? Im kinda thinking something like a sensor since its fine after being restarted once.
    Ive already changed the front and rear oxygen sensors, cardone maf, new plugs and wires. The maf and oxygen sensors seemed to fix it for about a week, but that was before it was this cold. The car really seems to run stronger in the 45-50* afternoon temps. I do have a very small exhaust leak coming from the flex i think, but you really have to listen to hear it. The only code it throws is P0420, Also the injectors are louder than any other car ive had. I ran injectors cleaner with no change. I only run BP 93 octane.
    Sorry for the long post, I hope this gives enough info to help solve the problem
    Thanks
    2005 Grand Prix GTP, 170,000 miles. Speed daddy headers with no cat, cone intake, MSD wires, flipped dog bones, transgo shift kit FOR SALE.
    2004 GTO six speed, stock for now.
  2. #2 Re: Cold problem?
    Jul 2012
    Chicago
    Does the mis and rough idle only happen when the motor is still cold? Or when it's up to temp?
    -Carl
  3. #3 Re: Cold problem?
    Sep 2012
    Murray, ky
    Engine temp Dosent really seem to affect it, it will be there till its restarted.
  4. #4 Re: Cold problem?
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    Intake temp sensor? Colder air is denser air. If the car thinks the air is a lot warmer than it is, the engine could run lean.
  5. #5 Re: Cold problem?
    Sep 2012
    Murray, ky
    I see where you coming from but wouldnt that make it have a lean condition code? Also where I'd the iat sensor on 04+. Is it built into the throttle body?
  6. #6 Re: Cold problem?
    Eau Claire, WI
    I'm pretty sure the temp sensor is right on the back side of the air filter box. Your sig says that you have a cone filter, so I'm not sure where it would have been relocated on your car.
    Generally, if the sensor fails it can go to ways.
    1) It shorts out reducing resistance. This would make the car think it's hotter and and trim the fuel a little.
    2) It burns out causing increased resistance which makes the car this it's colder and adds a little more fuel.
    Since your issue presents on very cold only, I thought maybe it was acting like it's hotter than it is.
  7. #7 Re: Cold problem?
    Sep 2012
    Murray, ky
    There was no sensor on the air box or in the piping connecting it, just the maf. I guess it's built in with the maf, idk why I said throttle body earlier.
  8. #8 Re: Cold problem?
    Sep 2012
    Murray, ky
    Also forgot to mention when it does this, it usually surges some too.
  9. #9 Re: Cold problem?
    I want to suspect it being a MAF issue, as that can play a roll in the transmission shifting and idle issue.
    I can't be for sure though, you could alsways try tapping on the MAF when it does this to see if anything changes.
  10. #10 Re: Cold problem?
    Sep 2012
    Murray, ky
    Hmm never heard that before, I'll give it a shot tomorrow.
  11. #11 Re: Cold problem?
    Yeah sometimes just a couple taps with a screw driver can show if a sensor is bad.
  12. #12 Re: Cold problem?
    Sep 2012
    Murray, ky
    I hope thats it, the MAF is still under warranty since its only about two months old.
  13. #13 Re: Cold problem?
    Sep 2012
    Murray, ky
    Well i started it up this morning and tapped on the MAF, It ran great all day today and my new one should be here tomorrow.
    Thanks Fivefingerdeathunch for that trick.
  1. Idle Problem when cold
    By Rockhound in forum 3.4L V6 (LQ1) DOHC
    Last Post: 06-16-2013, 01:25 PM
  2. cold weather brings cold engine
    By Garrett Mofford in forum Engine
    Last Post: 12-31-2012, 08:45 PM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. Problem after Installing Cold Air Intake
    By GPGT2004 in forum Engine
    Last Post: 10-03-2011, 06:23 PM
  5. Problem with rear speakers in cold weather
    By luvmyGP in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2009, 02:20 PM
