Thread: Squeaky window when rolling up
Results 1 to 3 of 3
  1. #1 Squeaky window when rolling up
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    My driver's side window squeaks/screeches when I'm rolling it up. Any ideas where I could lubricate the glass? I've tried a percussive fix, but that hasn't worked.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Squeaky window when rolling up
    St. Louis
    Get some dry lube from Autozone or the like and spray the window guides/channels on both sides while the window is fully down. Run the window up and down a few times and see if that helps. If not, you may need to pull the door panel to get to the rest of the guides.
  3. #3 Re: Squeaky window when rolling up
    Feb 2008
    Cumming GA
    Ugh, tried some dry graphite and some white lithium down the sides. That's not where the squeak is, so I took apart the door and lubricated the slides that go up and down - that's where the squeak is. Liberally sprayed them with lithium grease as well, tested it with everything apart, no squeak. Put everything back together, test it. Squeak returned... Maybe leaving it for a while will let everything soak and it won't squeak next time I roll it up.
  1. Window not rolling down
    By jestkdn in forum General Tech Discussion
    Last Post: 11-24-2012, 12:01 PM
  2. Squeaky squeaky
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2011, 12:52 PM
  3. So I found out why my rear window wasnt rolling down...
    By daniel981 in forum General Tech Discussion
    Last Post: 06-04-2011, 09:22 PM
  4. squeaky s/c belt
    By Joe m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 02:53 PM
  5. Squeaky Belt, HELP!
    By Pokey in forum General Tech Discussion
    Last Post: 05-27-2008, 08:17 AM
