what gear ratio is in the transmission? Pull codes when it slams (without turning it off) and report back. First thought is what others are alluding to.. you have the wrong gear ratio programmed.
Should be an easy fix. If you are using DHP, check the actual ratio from your bin in Tiny Tuner.
