Thread: Please Double Check I Wired this Correctly
Results 1 to 4 of 4
  1. #1 Please Double Check I Wired this Correctly
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    hey guys as some of you know i blew a sub a while back, i made this video to show how i wired my new ones to make sure its correct so id appreciate it if you would watch the video and see if i did anything wrong thanks in advance
  2. #2 Re: Please Double Check I Wired this Correctly
    Houston
    One thing I would check is your voltage after turning all your sound processing on. Turn your HU settings on how you normally listen to them and test again. Also, you want to root your amps RMS to the ohms of your speakers, not root your speakers RMS to the ohm of the speaker. And start the car, don't just turn to ACC. Also, if the tones annoy you, you can do this with the subs disconnected.
    **EDIT: Nevermind, your amp is far more powerful than your subs can handle. Use the speaker to ohm square.
  3. #3 Re: Please Double Check I Wired this Correctly
    GTP Level Member
    springfield IL
    Op you should watch the gain setting, those subs wont handle that power...
  4. #4 Re: Please Double Check I Wired this Correctly
    Nov 2011
    Decatur
    keith - the subs were disconnected the tone comes out of the speakers
  1. need someone to double check the build list
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2011, 09:13 AM
  2. Stupid question but i just like to double check
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2009, 09:50 AM
  3. Who Can First 'Correctly' Guess What........
    Last Post: 12-25-2008, 03:13 AM
  4. GP won't IDLE correctly. MAF sensor?
    By AEfor3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2008, 07:35 PM
  5. washed car/bay, polished stuff, halos wired up, pic heavy
    By kyle99gtp in forum Visual/Body Modifications
    Last Post: 06-07-2008, 10:18 PM
