Thread: Overkill ecm/tcm
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Overkill ecm/tcm
    I live here. DirtDog's Avatar
    Jun 2012
    So I'm looking at buying a set of tuned ECM/TCM from a guy on GSLS4. If u bought them would all I need to do is get a case relearn done? Or would I have to pay someone else to do more tuning on it
    Sent from my DROID RAZR using Tapatalk 2
  2. #2 Re: Overkill ecm/tcm
    Jan 1970
    Maquoketa, Iowa
    It depends on what's been done to them already and what you have.
    Jun 2012
    Its from an 08 gxp and its tuned for 87 octane. And aftermarket exhaust. The rest of the tune is just the standard tune will does for tranny and all
  4. #4 Re: Overkill ecm/tcm
    Mar 2012
    East TN
    From my understanding, case relearning is usually not something much to worry about. Mine snapped right in and fired right up as if nothing had been changed.
  5. #5 Re: Overkill ecm/tcm
    Dec 2011
    Champaign, IL
    Quote Originally Posted by AHarris90 View Post
    I just put my ECM/TCM in my 08 GXP and my car won't turn over at all, interior lights and radio all work. Bad connections? Bad tune? I unplugged the battery before and after removal but won't turn over one bit. Any ideas?
  6. #6 Re: Overkill ecm/tcm
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Quote Originally Posted by rideus View Post
    Is your ECM stock or is it a can tune? Try using your spare key to start engine.
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
    Jun 2012
    Also unless its the original ecm/ tcm from the car then u have to have dealer do a crank case relearn
  8. #8 Re: Overkill ecm/tcm
    Dec 2011
    Champaign, IL
    Quote Originally Posted by Chris BadAss View Post
    Canned tuned from Will @ Overkilled. He replied and said I need to do a key re-learn, which I'm in the process of doing. 3 ten minute cycles of leaving the key on with 10 seconds to off in between, keeping door shut. In the process now......see what happens.
  9. #9 Re: Overkill ecm/tcm
    Dec 2011
    Champaign, IL
    Quote Originally Posted by marines542 View Post
    I was aware of case re-learn but always assumed the car would at least start.......not be completely dead. Doing a key re-learn as we speak that I posted about. Fingers crossed and will keep posted. Thanks man.
  10. #10 Re: Overkill ecm/tcm
    Dec 2011
    Champaign, IL
    Car is still dead, tried other spare factory key and did 4, fifteen minute intervals with key on, kept door shut and no luck. Waiting on reply from Will. I don't know what the hell to do. Still have original ECM/TCM so I will put that on and see what happens.
  11. #11 Re: Overkill ecm/tcm
    Jul 2012
    Smart move keeping the original..I always keep a spare PCM just in case
  12. #12 Re: Overkill ecm/tcm
    Dec 2011
    Champaign, IL
    Fired right up with old ECM/TCM................about to ship this crap back to Overkill. Wasted 7 hours on this so far..................
    Jun 2012
    Try having dealership do a case relearn. The thing with the key on off for a period of time doesn't work with everyone from the research I've done on it. Its like a hit or a miss weather it works or not. And I've heard good things about overkill and plan to order a set myself soon.
  14. #14 Re: Overkill ecm/tcm
    Dec 2011
    Champaign, IL
    Heard good things myself but everyone I've spoken too, didn't have starting issues and were at least able to get it to the dealer for case re-learn. So I guess my option is to drive to dealer with original ECM, then have them install the tuned ECM and do a case re-learn all at once? Will has been helpful and is sending me another one to see if I have the same issues. My goal is to get it to work above everything else.
  15. #15 Re: Overkill ecm/tcm
    Jun 2012
    i understand...i always thought you had to have a case relearn to start the car...but i havent used any tunes yet so i personally have no experience with em. but i do hope you get it all worked out. keep us updated on what the problem was
  16. #16 Re: Overkill ecm/tcm
    Dec 2011
    Champaign, IL
    After driving around yesterday with the stock ECM, I tried one last time today, put in the tuned ECM and did about 6 cycles, car started right up. Ran rough at first, shut it down, unhooked battery, and started it back up. Ran just fine, except engine light was on, which is because of a case re-learn needed. Everyone kept telling me it is a tedious process and you just get lucky. Can't really comment on the tune yet as I've just driven it around the block.
  17. #17 Re: Overkill ecm/tcm
    Jun 2012
    well guess what i am buying...a used over kill ecm tcm and having it retuned by will for 100 bucks for my car
  18. #18 Re: Overkill ecm/tcm
    Dec 2011
    Champaign, IL
    Sweet - I had left the tuned TCM in with my stock ECM and I noticed a nice difference in the shifting so I'm anxious to get the case re-learn and "get in it"..........hope you have better luck with the key re-learn!
  19. #19 Re: Overkill ecm/tcm
    Jun 2012
    so for the tcm it doesnt have to be programmed by vehicle does it?
  20. #20 Re: Overkill ecm/tcm
    Dec 2011
    Champaign, IL
    Correct - I ran my stock ECM with the programmed TCM and worked great.
    Next problem is - my local "stealership" said they won't do a case re-learn on the car since it has a "modified ECM". They told me all they would do is flash it to make it "stock" again. They won't touch it with an aftermarket ECM. My check engine light is on and from what I've been told, the car could just die at any moment. Trying to figure out what to do next........
    In the end, I hope this is worth the hassle!
  1. overkill, zzp
    By 2001goldGTP in forum PCM Tuning
    Last Post: 01-11-2013, 02:11 PM
  2. Overkill pcm
    By rah575554eg in forum PCM Tuning
    Last Post: 08-20-2010, 09:29 AM
  3. overkill pcm
    By Biggie1720 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2010, 09:11 AM
  4. Will at Overkill
    By 04gpking85 in forum PCM Tuning
    Last Post: 11-05-2008, 09:48 PM
  5. Overkill PCM
    By gqjonb77 in forum General Tech Discussion
    Last Post: 10-17-2008, 10:44 AM
