Thread: air only blows through defroster
Results 1 to 5 of 5
  1. #1 air only blows through defroster
    Jun 2010
    stl
    I recently aquired an 03 gp with the 3.4l engine and it has 2 problems. The cel is on which i know is the cat converter (code p0420) and the heat and ac only blow out thru the defroster. Its getting cold out and i would liketo fix this. Are the blender doors ran from engine vacuum? It doesnt look likethe radio or the climate controls have ever been tampered with. Didnt see any loose or cracked vac lines under the hood but i could have missed something. The windshield was replaced, dont know if the climate control vac line is close to tbe windshield. So where or what should i do 1st? Thanksin advanced.
    Also the buttone that allows the air to come from the engine compartment is always lit, if i press the other b uttom (that allows the inside air to circulate) it does nothing but make the other buttom flash a few times. And i do know of the car being in a fender bender on the drivers fender. Its all been fixed but is there a vac line in there?
  2. #2 Re: air only blows through defroster
    reticulated wont work on defrost.
    under the hood is a vac tube, it runs around the engine bay and hooks to the engine, and back into the cab of the car, it works the vac pumps that move the air flow direction.
    look for any broken, or lines not plugged on on the engine.
    being you have a 3.4 engine, i have no clue where this line hooks up.
  3. #3 Re: air only blows through defroster
    Panama City Beach, FL
    You have a vacuum leak. Look under the hood. Thanks for joining for a googleable question.
    Ohio
    Btw, you don't own a 2003 gp with a 3.4...
    Just saying
  5. #5 Re: air only blows through defroster
    Jun 2010
    stl
    I meant 3.8l. And it turned out the plastic in the inside of the knob was broken. Guess i shoulda checked tht 1st
  1. Rear Window Defroster - Fuse/Rely Location
    By 99XC600 in forum General Tech Discussion
    Last Post: 12-10-2012, 07:49 PM
  2. Help!! Defroster, Radio, Power Doorlock Problem
    By Sykkel in forum General Tech Discussion
    Last Post: 11-08-2012, 11:40 AM
  3. 04 rear window defroster
    By mikev69 in forum General Tech Discussion
    Last Post: 01-23-2010, 08:08 PM
  4. 2002 GTP Rear Defroster Problems
    By irex511 in forum General Tech Discussion
    Last Post: 01-21-2010, 05:54 PM
  5. 07 Grand Prix - Rear defroster messes up radio
    By thevolkp in forum General Tech Discussion
    Last Post: 10-23-2009, 10:28 AM
