Thread: Dual borlas for $300 installed?
Results 1 to 20 of 20
  1. #1 Dual borlas for $300 installed?
    Dec 2012
    Chicago
    Is it worth it for 2 borlas (2.25") at 100 each and a $100 install, will the sound be worth it? (called my local mechanic and he said he could install each muffler for 50 ea) for a grand total of 300 dollars for everything.. Does anyone have borlas and the rest stock? Does it sound good? is it worth the 300 dollar price tag not including new tips?
  2. #2 Re: Dual borlas for $300 installed?
    May 2012
    Burlington, Wisconsin
    I'd go for it. Borlas tend to be the best sounding on Grand Prixs in my opinion.
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
    I have Borlas and kept everything stock...sounds amazing. I paid around $70 shipped each for my Borla a few years ago and paid $50 to have then welded on so around $200 total.
    04 Comp G.
  4. #4 Re: Dual borlas for $300 installed?
    Dec 2012
    Chicago
    OK thanks for the feedback I might go for it then
  5. #5 Re: Dual borlas for $300 installed?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    You can get Borlas for cheaper than that..
    Borla Pro XS
    Well near the same price, $10 cheaper on this site for the 2.25 in/out center.
    Ditto on Wicked Nikki's that's where I bought mine from
    04 Comp G.
  7. #7 Re: Dual borlas for $300 installed?
    $100 to install? Shouldn't cost more than $50.
    Shop around $100 your paying premium prices. Try a smaller mom and pop shop.
    04 Comp G.
  9. #9 Re: Dual borlas for $300 installed?
    Jun 2011
    Quote Originally Posted by slick2500 View Post
    Kinda what i was thinking, $100 to cut and weld is a bit high.
    But borlas are the most expensive, under $100 is reasonable i think.
    Sorry should of clarified myself a bit more. Under $100 for each Borlas is definitely resonable...as the saying goes you get what you pay for I didn't hesitate to buy a set because of what they were and how they made our cars sound without having the aggravating drone or everybody can hear me down the block thing going on. $100 to install is pretty steep considering there's probably some type of exhaust shop every mile someone will do it cheaper simple because of how rather easy it is. Paid $10 to have my old mufflers cut off. Went to another shop and paid the $50 to have it installed.
    04 Comp G.
  11. #11 Re: Dual borlas for $300 installed?
    Apr 2012
    Goderich, Ontario
    In/out center will require some extra pipe bending to line everything up. You need offset in/ center out. Like in redcompg's pics.
  12. #12 Re: Dual borlas for $300 installed?
    SE Level Member schollianmj's Avatar
    Dec 2012
    Virginia
    Me thinks I found my first thing Im doing to this car... Gotta do something with this stock Exhaust. As far as install, what about cutting the stocks out with my sawzall and then clamping the new ones in? I know welding is better, but if cost is a factor (and when is it not??) shouldnt this work out just fine?
    Sawzall FTW it'll work just fine. You could get some clamp on tips and make sure they will fit over a 2.25 pipe and go that route instead of welding.
    04 Comp G.
  14. #14 Re: Dual borlas for $300 installed?
    Dec 2012
    Virginia
    Thats what i thought. That way also If in three weeks I realize I don't like the tips i can just un-clamp and replace. and not waste money on welding. granted once everything is how I know I want it I would have it welded...
  15. #15 Re: Dual borlas for $300 installed?
    Quote Originally Posted by schollianmj View Post
    clamping new mufflers to the factory pipe wont work out so good, the need to be welded on due the odd shape of the pipes.
    or piece together a whole new cat back, res,( glass pack 20 bucks) y pipe, and mufflers, you could go that route for maybe 100 more. then the 300 listed above.
  16. #16 Re: Dual borlas for $300 installed?
    Dec 2012
    Virginia
    What do you mean odd shape of the pipe? they not round in the back of this car? (Obviously I havent slid my butt under there in this snow yet... )
  17. #17 Re: Dual borlas for $300 installed?
    the stock pipes are far from round like the end of a new muffler. more egg shaped i guess. not real true round though.
  18. #18 Re: Dual borlas for $300 installed?
    I had all of my catback built for like 150, what shop is raping you for a hundred bucks to install two mufflers?
    Find a better exhaust shop.
  19. #19 Re: Dual borlas for $300 installed?
    Dec 2012
    Virginia
    Didnt know that. that would have been bad had I whacked off my muffs and THEN found that out..
  20. #20 Re: Dual borlas for $300 installed?
    i found out by calling Jy's all over looking for a muffler for my regal. found a yard with a gp in it, had them cut it off, when i got there it was off a factory cat back, the guy told me over the phone it was clamped and they would cut the pipe past it.
    i got there it was welded to the pipe, and no wheres near round, so i had to pass on it, as i have after market pipes already. which are very round at the ends. the 2 will never clamp up, not ever.
  1. Those of you with Borlas?
    By gpgt04 in forum Off Topic Discussion
    Last Post: 05-24-2011, 07:45 PM
  2. a/c to dual a/c
    By grandprix97gp in forum General Tech Discussion
    Last Post: 11-08-2010, 09:50 PM
  3. Dual exhaust on se?
    By Squishy in forum General Tech Discussion
    Last Post: 02-01-2010, 02:50 AM
  4. anyone have pics of the HUD dual gauge pod installed?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-16-2009, 12:29 AM
