okay recently i started the car and it sounded like a groaning/scratching coming from the passenger side. it was present through all rpm ranges. Today i pulled the serpentine belt and checked all the pulleys. when i held my hands at 6 and 12 o clock, there is a little play in the pulley. I also removed my coolant reservoir to loosen the tensioner for the belt and there is no coolant in there. The whole passenger side is wet including a coil pack. i think it is coolant... it has to be. i also noticed dampness below the lim almost as it is leaking, but i have yet to see it leak from there. I know about the elbows but they seem good still. I randomly got a code for p0304, cylinder 4 misfire. I cleared the code and it never came back. I took off the oil spout on the valve cover and there was moisture on it.. not coolant, but water almost like condensation. I also pulled the dipstick and it looks normal, light brown and not milky.
I have not checked the plugs for coolant or checked the radiator for bubbles. Does this sound like possibly a leaking lim or a head gasket. Also does the water pump sound like it needs replaced?
Chris
