07 grand prix cars have tpms sensors in the wheel as opposed to the 04-06 relying on abs wheel speeds to determin inflation pressure.
So this means if you put an 07 or higher dic in an 06 and under car,, you will be annoyed with constant tpms error messages...
06 and up dic/radio bezels have a passenger airbag indicator light built in to the moulding...
I also have listed on here a five button dic kit with temp sensor and compass sensor removed from an 04 if anyone shall need one.
And swapping the compass module is easy if you dont have monsoon, just go inside your trunk and shove your hand up through where the monsoon amp would mount and connect it by feeling around, cuts 30-45 minutes from your install time!
