Thread: DRL headlamp continuing problem...NEED SOME ADVICE
Results 1 to 3 of 3
Synergy LS DRL headlamp continuing... 11-29-2012, 08:46 AM
LeadfootCJ7 Re: DRL headlamp continuing... 12-02-2012, 08:13 PM
Synergy LS Re: DRL headlamp continuing... 12-02-2012, 10:38 PM
  1. #1 DRL headlamp continuing problem...NEED SOME ADVICE
    Aug 2012
    Arizona
    I hope someone can give me some tips...my daughter-in-law's 2006 Grand Prix has a continuing intermittent electrical problem with the headlamps. It is a long story so to try to keep it short:
    Replaced DRL relay about 9 months ago when at first her daytime running lights would not turn off when the car was turned off
    About 3 months later the new relay fried (actually melted) and also burned the fuse block at the location it plugs into. I attributed that to a chinese made relay bought from NAPA and had to replace the whole fuse block. Purchased one form a local scrap yard...relays and all and installed it.
    About 6 weeks ago she called me to tell me daytime running lights were not on while driving, and then actually no headlamps at night. I bought a GM DRL relay from a Chevy dealer and put it in...all worked fine.
    2 weeks later she calls again..my lights are out. I had her plug in the old relay for kicks and they came back on.
    That has now happened at least twice more, so she gave me the car to drive a few days.
    Last night it did it to me, so I had the chance to work the headlamp switich and no matter what I did the low beams would not come on...only high beams. I didn't get home until late last night so I will look at it again later.
    Right now I suspect some connector loose, but I am wondering if anyone has any other suggestions, or has experienced this and can give me some other ideas of what to look at?
    Thanks!!!
  2. #2 Re: DRL headlamp continuing problem...NEED SOME ADVICE
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Def strange issue. Has the car ever been wrecked?
  3. #3 Re: DRL headlamp continuing problem...NEED SOME ADVICE
    Aug 2012
    Arizona
    No it has not....
  1. Replies: 30
    Last Post: 12-12-2012, 04:35 PM
  2. Pesky Headlamp non function problem...NEED ADVICE
    By Synergy LS in forum General Grand Prix Discussion
    Last Post: 12-12-2012, 01:54 AM
  3. Finally continuing customization...
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 07-28-2011, 10:11 AM
  4. need to diagnose a problem with my grand prix. need advice.
    By emmaamelia in forum General Tech Discussion
    Last Post: 01-25-2011, 07:51 PM
  5. shift problem, need advice
    By spassytaz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-16-2009, 06:37 PM
