if the wires click on, i suppose they would work.
like i said, pull the engine forward, then slide the socket on the plug first then stick the extension and ratchet to the socket, it may not go in all the way, just hook it best you can. or use a swivel on the socket.
the O2 sensor socket is defective I think cause none of extensions or ratchets fit it barely goes 1/4 of the way in or out of the engine bay I tried braking the O2 sensor loose and the extension popped out and I cut my middle finger knuckle pretty bad so I called it a night at like 3:00-4:00 am. thanks for the help.
