Thread: Changing spark plugs
Results 1 to 11 of 11
  1. #1 Changing spark plugs
    Nov 2009
    California
    Hi all, my '01 Grand Prix turned 100K recently. Need to change the plugs as it is due for smogging in a few weeks. Front side looks easy. But the back side? Pretty slim clearence there. Any tips to make this easier? Also what size socket for the plugs? Seems like everything is mix and match with metric and SAE on cars these days. Thanks in advance. Chumley
  2. #2 Re: Changing spark plugs
    this is from last night im to lazy to type it out http://www.grandprixforums.net/last-...elp-48766.html
  3. #3 Re: Changing spark plugs
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    search.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Changing spark plugs
    Pennsylvania
    To make it easy, you rock the engine forward. Or you learn to be a spark plug ninja and just shove your man-hand down there.
    Plenty of threads on this already, though.
  5. #5 Re: Changing spark plugs
    Nov 2009
    California
    Thanks, I do happen to have fairly slender hands , but they don't contort or RECOVER as well as they used to. What bolts do I loosen to rock the engine forward? Any issues with connections or transaxle? I don't have a service manual for this car (yet) Thanks.
  6. #6 Re: Changing spark plugs
    London Ont, Canada
    take the 2 bolts outta the dogbones, get a ratchet strap hook to front and back, giver her hell and she moves lol #2 is the most painful one anyway you do it
  7. #7 Re: Changing spark plugs
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Hey Chumley,
    I know this is an older post and i'm still the new guy here, and you may have fixed this already, but i had to change the plugs on my GP GT and your right the back plugs are a PITA the only way i could get the number 6 plug and wire out was to remove the O2 sensor. Autozone sells the socket you need to remove it i have no idea on how much they are anymore. That's the only way I have been able to get that darn plug and wire out, just be careful not to burn yourself on the exhaust manifold back there (ouch), and don't forget to reinstall the O2 sensor before you start the engine.
    Hope this helps
  8. #8 Re: Changing spark plugs
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    instead of moving the o2 just put the 5/8 on it and 13/16 wrench on it.. save the extra work.. i did it using the 5/8 then puttin the 13/16 socket an extension and got em all out without a big delay change all 6 in about 35 minutes..
  9. #9 Re: Changing spark plugs
    FWIW, I've never removed the rear o2.
    Remove misc. engine pull brackets...spark plug metal shields...gold manifold shields...etc.
    All that junk isn't needed and gets in the way.
  10. #10 Re: Changing spark plugs
    brunswick
    i also got rid of the shields in the back the first time i changed my plugs
  11. #11 Re: Changing spark plugs
    May 2013
    Ontario
    A couple of helpful tips to remove the rear plugs: Remove the plastic acostic cover rear braket (two 13mm nuts)
    Remove the oxygen sensor (7/8" oxygen socket)
    These two simple tasks will make the rear bank #2, #4 and #6 plug removal quite easy without having to rotate the
    engine forward.
  1. changing back 3 plugs
    By paul s gtp in forum General Tech Discussion
    Last Post: 06-11-2011, 06:34 PM
  2. Changing Freeze Plugs
    By tmackster in forum General Tech Discussion
    Last Post: 02-06-2011, 11:44 PM
  3. Changing Spark Plugs on a 2004 Grand Prix
    By Clarkie59 in forum General Tech Discussion
    Last Post: 01-29-2011, 11:23 AM
  4. Changing Back Spark Plugs
    By Badbird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2009, 07:24 PM
  5. Changing the Spark plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:24 AM
