Thread: Changing Back Spark Plugs
Results 1 to 19 of 19
  1. #1 Changing Back Spark Plugs
    Thunder Bay
    It looks like its going to be hell trying to change the rear spark plugs. Does anyone have any tricks or know where a 'How-To' article is to get at them?
  2. #2 Re: Changing Back Spark Plugs
    Banned - Busted For Scamming
    Feb 2009
    You could rock the motor forward, but i had no problems getting to them without doing that. They arent as bad as they look.
  3. #3 Re: Changing Back Spark Plugs
    With headers, no they aren't...but with stock manifolds, it sucks. Remove the dog bones and rock the motor forward
  4. #4 Re: Changing Back Spark Plugs
    I use a socket and ratchet. If you ever change a 3.1 or 3.4 motors plugs, you'll realize how easy ours really are.
  5. #5 Re: Changing Back Spark Plugs
    Jersey
    Just reach back there.
    16' wrx sti- stock
  6. #6 Re: Changing Back Spark Plugs
  7. #7 Re: Changing Back Spark Plugs
    SE Level Member Planeboy18's Avatar
    Cleveland Ohio
    Get a midget and have him crawl back there and pull them out. But seriosly, just drive the car up in front of something you can put a ratcheting tie down on and pull the 2 dog bone mounts off, put the tie down on the front engine hook, then just ratchet the engine forward until you can get back there without breaking a nail. Sorry I had to. That's the way I've always done it with 90* and 60* degree GM engines.
    04 GP GT (1st car now my G-Ma's):
    97 GP GT (GF's): "Project Pink Power"
    00 VW GTI VR6 (15*V6): Slow and Low, That is the Tempo
    91 VW GTI 8v: Big Plans
  8. #8 Re: Changing Back Spark Plugs
    Thunder Bay
    Thanks for the info guys, I appreciate it. I will take a crack at it later.
  9. #9 Re: Changing Back Spark Plugs
    iowa
    Take the bolts out of the motor mounts and use a pry bar to pull motor back. On the motor mounts there are holes on the bottom side push bolts through there and it holds the motor up.
  10. #10 Re: Changing Back Spark Plugs
    SE Level Member FRESCOLIO's Avatar
    CHICAGO
    Make sure the engine isn't hot.
  11. #11 Re: Changing Back Spark Plugs
    Quote Originally Posted by FRESCOLIO View Post
    actually, do it right after you get done driving the car so you learn a lesson. hot engines suck, but sometimes you gotta deal with them.
  12. #12 Re: Changing Back Spark Plugs
    GT Level Member BoostedComp's Avatar
    Youngstown
    ha did my plog last thursday and started doing it 15 min after turning the car off... my hands are just starting to feel better
  13. #13 Re: Changing Back Spark Plugs
    CHICAGO
    . Take your hose and spray the compartment. Engines somehow cool down quicker with a little assistance.
  14. #14 Re: Changing Back Spark Plugs
    Charles City, IA
    Ever check the trannyfuild on a 3.4 I think it is? The fill cap is right under the crossover and you have to pull out a plug underneath and fill it till it runs out. It sucks.
    SMGPFC Two Nipple General
  15. #15 Re: Changing Back Spark Plugs
    Charles City, IA
    After you burnt your hand once you didn't stop?
  16. #16 Re: Changing Back Spark Plugs
    Best said by one of my buddy's after I refused to pull the plug wire next to his hot header...
    "Can't be a vagina all your life"
    And preceded to roast the side of this hand pulling out the plug wire. What a bad ass.
  17. #17 Re: Changing Back Spark Plugs
    May 2008
    staten island,NY
    universal sockets are your friend
  18. #18 Re: Changing Back Spark Plugs
    muskego
    hehe... did it myself for the first time last weekend and learned from these posts... saw the pic of the guy's arse all up in the air under the hood... yeah, I lived it too good times. As for rocking the engine, I found after a little work (thirty minutes of putzing to learn, I can now rock the car forward pulling on the bumper(ish) area and push in a retaining screw to hold the engine forward in under a few rocks
  19. #19 Re: Changing Back Spark Plugs
    Standing in the engine compartment...I call it the spidamonkey
  1. spark plugs
    By silverstreak in forum General Tech Discussion
    Last Post: 08-01-2009, 06:09 PM
  2. spark plugs
    By Nos shottss in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-12-2009, 09:34 PM
  3. Changing Spark Plug Wires, HELP!
    By PsychoGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 12:56 AM
  4. Changing the Spark plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:24 AM
  5. Spark Plugs
    Last Post: 07-27-2008, 10:45 PM
