Yup. One side to ground other to the pcm to enable performance shift. Hope you didnt put 12v into the pcm side.
Sent from my SPH-L710 using Tapatalk 2
No I didn't. I was talking about the rocker switch has 3 connectors at the bottom of it a 12v, Acc., and a ground. I connected the red wire to the 12v connector on the switch and red and black wire to the ground connector on the switch but it worked right tell I got the bulb for the I.P. cluster and put it in. I'm going to take the bulb out and see if it go's back to normal (which I'm sure it will). It's has something to do with the bulb.
I fixed the problem. Thanks for your guys' ideas.
