Thread: 97 gtp
Results 1 to 11 of 11
Jay Clegg 97 gtp 10-07-2012, 06:01 PM
00grandprixgtp Re: 97 gtp 10-07-2012, 06:24 PM
Jay Clegg Re: 97 gtp 10-07-2012, 06:31 PM
Scottydoggs Re: 97 gtp 10-07-2012, 06:38 PM
RedneckGTP Re: 97 gtp 10-08-2012, 11:13 AM
Jay Clegg Re: 97 gtp 10-07-2012, 07:03 PM
Zef_66 Re: 97 gtp 10-08-2012, 12:17 PM
Jay Clegg Re: 97 gtp 10-08-2012, 04:16 PM
00grandprixgtp Re: 97 gtp 10-08-2012, 11:15 PM
Jay Clegg Re: 97 gtp 10-09-2012, 04:51 AM
Jay Clegg Re: 97 gtp 10-20-2012, 07:48 AM
  1. #1 97 gtp
    Oct 2012
    wv
    Need to find a cooling leak on my 97 GTP. Just replaced pump and 90 degree bypass. Still have a leak showing up around the oil filter area. Intake looks dry on front of engine and rear head appears to be dry. Can any one help?
  2. #2 Re: 97 gtp
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    could be the front cover where the wp bolts or could be the rear heater hoses? or could be that other elbow under the alt that is metel
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: 97 gtp
    Oct 2012
    wv
    I repaced all o-rings under the alt and put sealer on all bols that looked like they needed on the pump is it hard to get that front cover off?
  4. #4 Re: 97 gtp
    clean the engine up get it dry, then pressure test the system. its a pump that you put where the rad cap goes and you pump it up, then go look for the leak, you do this with the car off.
  5. #5 Re: 97 gtp
    GT Level Member RedneckGTP's Avatar
    Oct 2012
    Chelsea, MI
    do this!
    you can test it when its NOT HOTT! and you will find out if and where you have a leak because 1 you wont have a running engine and 2 it wont be hott...
    I sell them on my truck. very very handy tool! it will be cheaper to buy the cooling system pressure tester than it will be to pay a mechanic.
  6. #6 Re: 97 gtp
    Oct 2012
    wv
    Ok, I tried to get some dye today but had no luck. I may take it to a shop this week and see what they say. It has 190k on it but still runs good and looks good so would like to fix it.
  7. #7 Re: 97 gtp
    PA
    Did you put thread sealer on the threads of the bolts that go into the water jackets on the water pump?
    2001 GSE
  8. #8 Re: 97 gtp
    Oct 2012
    wv
    [QUOTE=Zef_66;898288]Did you put thread sealer on the threads of the bolts that go into the water jackets on the water pump?[/QU
    Yes I did but going to take a close look at them to see if the leak could be there.
  9. #9 Re: 97 gtp
    Apr 2009
    Elkhart
    Did u use the oring that was on the plastic oring and put it on the one on the alt ? Because if u did that's the prob it would be purple and it is smaller then the stock one
  10. #10 Re: 97 gtp
    Oct 2012
    wv
    Quote Originally Posted by 00grandprixgtp View Post
    I used the one I got from the dealer, it was not purple, it was either orange or red, the one on the plastic elbow would be way to small. I did have to reuse one on the heater hose, because the dealer only had one which I thought was strange that they didnt have enoungh on hand to do a job, that hose isnt leaking.
  11. #11 Re: 97 gtp
    Oct 2012
    wv
    No leak so far. Found a damaged oring on tension housing. TKS for your help.
gtp
