Thread: New battery issues
Results 1 to 7 of 7
  1. #1 New battery issues
    Oct 2011
    Canada
    Hey guys i just recently bought a brand new battery for the winter. After installation its taking about double to triple to time to turn over. Does this have to do with higher CCR than my old battery??
  2. #2 Re: New battery issues
    SWPA
    Higher CCA will make it crank faster. You need to check your connections.
  3. #3 Re: New battery issues
    St. Louis
    Make sure your battery cables are clean and tight. And no, the higher CCR shouldn't hurt it.
  4. #4 Re: New battery issues
    Oct 2011
    Canada
    Alright since its a new battery shall i take the terminal cleaners to it and retighten???
  5. #5 Re: New battery issues
    every time i disconnect my battery, it resets the pcm, and it will crank over longer then usual. after a few starts, its back to normal. the trans may feel like its shifting differently as well as the trans relearns how you drive.
    so if it does it again after you clean the terminals, let it go for a day or 2, it should clear up on its own, and be back to the 1/2 of a turn and start, like it was.
  6. #6 Re: New battery issues
    Oct 2011
    Canada
    Alright so it basically needs to settle in huh? Well ill give it a clean and retighten, couldnt hurt.
    Also the little wire that goes from the negative wire to the hood resistor(or w.e its called) whats it do exactly\
  7. #7 Re: New battery issues
    Oct 2011
    Canada
    Hey guys, two days later the car starts up flawlessly. Still wondering what that little wire is there for.
  1. Swapped battery, now starting issues.
    By elejes in forum General Tech Discussion
    Last Post: 06-23-2012, 10:10 AM
  2. Help battery dead but other issues are concerning
    By 87IROCZOWNER69 in forum General Tech Discussion
    Last Post: 02-06-2012, 09:22 AM
  3. Battery Reloacation issues
    By MrClean in forum Audio, Security & Visual Electronics
    Last Post: 08-30-2010, 08:09 PM
  4. Battery issues with 2008 GXP
    By Injun #4 in forum 5.3L V8 (LS4)
    Last Post: 04-05-2010, 12:57 PM
  5. Electrical issues. alternator? battery?
    By Alex W in forum General Tech Discussion
    Last Post: 01-30-2010, 09:18 PM
