Thread: GT Sputtering under load- only at idle and slowing down
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    GTP Level Member apierce1289's Avatar
    United States
    Quote Originally Posted by 99GrandPrixGTP View Post
    The relearn is done on a diagnostic tool, it's call a "crankshaft position variable relearn"
    Just curious. Can you do this wth hptuners software?
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
    Oct 2012
    Ok so plugs and wires didn't fix in. And the problem got worse. Now it won't run at idel. I can start it by giving it gas, and shirt and drive quick and runs fine on the road. But as soon as the rpms. Get less the 1000. It dies ????
    Sent from my BlackBerry 8530 using Tapatalk
  3. #23 Re: GT Sputtering under load- only at idle and slowing down
    Try unplugging the maf sensor then starting it and see if it's any better.
  4. #24 Re: GT Sputtering under load- only at idle and slowing down
    What plugs did you use.
    Oct 2012
    I used auto light platinum I think, they where like 8 bucks a piece. I'm gonna try unpluging in the morning if it doesn't start agin. Right now its starting again. But still has the rough idle. But when I drive its fine. Got good pep and everything!
    I was reading about this fuel pump resistor issue. Do you think that could come in to play? Or are the syptoms not the same?.
  6. #26 Re: GT Sputtering under load- only at idle and slowing down
    lots of people here will tell you platinum dont run well in these motors. you may want to try a set of iridium plugs.
  7. #27 Re: GT Sputtering under load- only at idle and slowing down
    Return the plat plugs. The fuel pump res would make it not start at all or start for a few seconds and die.
    Oct 2012
    Ok that's worth a shot, but if it was the plugs would it run perfectly in all other ways. Right now its starting again. And is fine just putts at idle when I go to stop and take off.
    Oct 2012
    Ok new issue, I beleave its related.. The cars been running ok for a little bit. I'm driving down the road and the car hesatates like its going to die again... But dosnt , in stead the tac dies.. For looking in to it it sounds to be close to crank shaft sensor. Now I replaced the cam shaft sensor because that's the code I had. But looking at the wires. I'm guessing the crank shaft sensor could throw this code as well. What ya guys think. You think that's it?
  10. #30 Re: GT Sputtering under load- only at idle and slowing down
    Oct 2012
    MI
    did u check the fuel pressure regulator. Pretty sure 2003 & older are still on the fuel rail. Pull off the vacuum hose on the top of the reg & see if it has any fuel in the vacuum hose. If so the diaphram is bad & the reg needs to be replaced.
  1. GTP sputtering, misfireing under load
    By LSXHP in forum General Tech Discussion
    Last Post: 10-23-2012, 04:31 PM
  2. sputtering under load
    By Jay7199 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2011, 01:44 PM
  3. gtp: sputtering on idle then dies
    By pontiaccrazy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 07:22 PM
  4. low idle....near stalls....can't handle load or deceleration...ahh
    Last Post: 05-16-2009, 01:18 PM
  5. Vibration when slowing down
    By 03GPScottyd in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2008, 03:15 PM
