Thread: GT Sputtering under load- only at idle and slowing down
Results 1 to 20 of 30
  1. #1 GT Sputtering under load- only at idle and slowing down
    Oct 2012
    hey guys and gals, 25 male from mass here. single dad 4 kids lol. ok heres my problem. I just got a 2000 grand pix gt. really nice looking car but thinking it wasn't maintained vary well. but its all i could get. 500 bucks.. so im to fix it myself. i dont mind though. i just have to pick and chose where to start with money.. ok so the car ran great for the first few days... then just now im down the DMV getting the reg.. when all of a sudden it starts to sputter at low rpms. when i start to go , it smooths out. i did how ever notice like a slight wining noise when i give it gas.. so i took it down to the ol' auto zone. engine light was on since i bout it a week ago.. i was told evap leak when i bought it. so they plug it in and give these code. :
    p0442( evap) p0301(misfire in #1) and p0341 (canshaft sensor) so being as i can only do one at a time, and at least need the car to run like it was a week ago. where do you think i could start to do so.
    Sent from my BlackBerry 8530 using Tapatalk
    Oct 2012
    Also noticed today driving it to work and dropping off the kids, it just would sput and die while driving, I pull over and start right back up.... Did this 3 times on a 20 min drive, just out of no where to.. But would start right back up no problem then go just fine..
  3. #3 Re: GT Sputtering under load- only at idle and slowing down
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    My best guess would be a crankshaft sensor. Fixing that and the evap problem will likely take care of the misfire. Good luck, Sir!
    02 sedan, top swap
  4. #4 Re: GT Sputtering under load- only at idle and slowing down
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    or simple tuneup.. plugs and wires.. but as said above start with sensor.. and still give it a tune up.. just because
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #5 Re: GT Sputtering under load- only at idle and slowing down
    Sep 2012
    Calgary
    my trac off light turned on and the rpms dropped to zero while driving; few minutes later would stall; started up right away no problem. replaced crank position sensor. you need a harmonic balancer puller thingy; took to my shop about 1.5hr and $80 parts.
  6. #6 Re: GT Sputtering under load- only at idle and slowing down
    Dec 2010
    long prairie, mn
    so is your problem fixed?
    02 sedan, top swap
    Oct 2012
    Just got done work and heading to autozone to get the camsaft sensor. Hopeing it will get me to another week to do plugs and wires.. Ill keep ya posted thank you so much
  8. #8 Re: GT Sputtering under load- only at idle and slowing down
    Sep 2012
    Calgary
    ya fixed er right up.
    ive got bigger problems now!! im getting a ton of shuddering and no power. changed TPS, cleaned TB, changed plugs, changed both O2 sensors. thinking now it might be either TCC, ICM, or cat. im tired of guessing. taking it to shop monday morning.
    Oct 2012
    Well replaced the cam sensor... No change... Didn't have enough for plugs.. Think it would kill it to drive a week?
  10. #10 Re: GT Sputtering under load- only at idle and slowing down
    Sep 2012
    Alberta
    Oh and to answer your question about driving it, I've noticed a massive loss in my fuel mileage so mine has been parked, I'd suggested not risking it getting as bad as mine where it stalls at every red light and just leave it parked... Personal preference
  11. #11 Re: GT Sputtering under load- only at idle and slowing down
    Sep 2012
    Alberta
    I have a 99 gtp and have gone through the EXACT same thing you have, first thing, did you do the crankshaft position variable relearn after replacing the sensor? If not start there, if so, you'll be right where I am, I had cat and "u-bend" cut out, I've replaced plugs and wires, and I'm still having a massive misfire/stalling/sputtering issue, taking it to my local gm dealer, it'll be pricy but I'm sure they'll find the issue, anyways, I will keep you posted on what I fin out if you would be so kind as to doing the same, I've been chasing this problem for two months and throwing money at the wrong stuff, as I'm sure you have too and would rather not anymore, chow for now
  12. #12 Re: GT Sputtering under load- only at idle and slowing down
    Did you change the cam sensor or crank sensor?
    Oct 2012
    Thank you so much! plz do keep me posted. I didn't even know about the sensor relearn.. How whole I do it ? I replaced both sensors just cause I found on the 3.8 they piggy back on each other so one can fault the other. Plus I found a video when pulling the belt and the water pump pully I found them pretty easy to replace..
    So after that didn't solve the problem I switched the coil packs to see if the problem moved. I scanned again. Same misfire..
    So I got a few bucks and replaced #1 plug and wire! Seemed to have smoothed it out.. Going to get it scanned again and see. Will keep ya posted..
    I did find that I think the valve cover gasket has a lot of oil sweat on the bottom side.. The plug when I pulled it was covered with dirt and oil?? So I gave the valve cover a little tighten.. Thinking I may do that replace real soon. And the rest of the plugs. They look like the original wires, numbered and all..
    So well se how it does. Plz keep me posted as well
  14. #14 Re: GT Sputtering under load- only at idle and slowing down
    Sep 2012
    Alberta
    The relearn is done on a diagnostic tool, it's call a "crankshaft position variable relearn"
  15. #15 Re: GT Sputtering under load- only at idle and slowing down
    Sep 2012
    Alberta
    I replaced the crankshaft position sensor only... And my car hasnt thrown a code for anything else since I've owned it, yet its performing so erratically that I can't even drive it to the store without it stalling and burning a crap load of gas... What can cause up to 30 misfires on random cylinders? I can't figure it out
  16. #16 Re: GT Sputtering under load- only at idle and slowing down
    Quote Originally Posted by 99GrandPrixGTP View Post
    try a tune up yet? new plugs and wires.
  17. #17 Re: GT Sputtering under load- only at idle and slowing down
    Sep 2012
    Alberta
    Yes I've replaced plugs wires and fuel pump since the crank sensor
  18. #18 Re: GT Sputtering under load- only at idle and slowing down
    a really clogged cat could do that. does it feel like its got no power at all, like its being choked?
    check the fuel pressure as well.
  19. #19 Re: GT Sputtering under load- only at idle and slowing down
    Sep 2012
    Alberta
    I've done a cat delete and replaced my fuel pump already as well
  20. #20 Re: GT Sputtering under load- only at idle and slowing down
    bad ICM maybe. or cracked coil? check the ground wire on the side of the head, make sure its tight and not broken off.
  1. GTP sputtering, misfireing under load
    By LSXHP in forum General Tech Discussion
    Last Post: 10-23-2012, 04:31 PM
  2. sputtering under load
    By Jay7199 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2011, 01:44 PM
  3. gtp: sputtering on idle then dies
    By pontiaccrazy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 07:22 PM
  4. low idle....near stalls....can't handle load or deceleration...ahh
    By gotboost3 in forum General Tech Discussion
    Last Post: 05-16-2009, 01:18 PM
  5. Vibration when slowing down
    By 03GPScottyd in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2008, 03:15 PM
