Thread: Engine fusebox wires melted
Results 1 to 20 of 29
  1. #1 Engine fusebox wires melted
    Dec 2010
    DMV
    Ok on the way to work I noticed the power went out in my car then came back on. It did it a second time then I pulled over and noticed smoke from the engine bay. Upon further inspection the wire that connects to the fuse box was melting and smoking. Ok at that moment this was what was running In my car
    I had a 140 watt inverter plugged up with my iPhone walls charger plugged into. Ac was running. Sub was on BUT kept cutting in and out. Come to think of it the sub wire was smoking as well.
    What happened? Too much power on the wires? Can I just replace everything? I'm going to junkyard in the morning so can I just get another one?
    How can it be removed? Easy?
    Edit
    Her is my nice hood burn mark
    Will b covering that with a sticker lol.
    Also her is the culprit
  2. #2 Re: Engine fusebox wires melted
    Houston
    What size wire and what size fuse did you use?
    Dec 2010
    DMV
    Well the sub wire itself is fine. That's never been an issue.
    The wire that is in the pic is the wire that connects to the top of the fuse box. The one that screws down.
  4. #4 Re: Engine fusebox wires melted
    Houston
    How is the inverter wired up?
    Dec 2010
    DMV
    Inverter is just a cig plug. Plug in and go.
  6. #6 Re: Engine fusebox wires melted
    Houston
    Hmm, that wire shorted on something. I would check at your S/C Idler pulley. After replacing a battery, my cables started rubbing on that pulley. And if it rubbed that jacket off and the wire touched the idler bolt, there is nothing to stop the short because that wire isnt fused.
    Dec 2010
    DMV
    That's s good idea. I'll check it in the later tonight. I wrapped the exposed wire in black electrical tape. Should that b ok?
  8. #8 Re: Engine fusebox wires melted
    Houston
    Noooo. Replace it.
    Dec 2010
    DMV
    That's the issue. Can't figure out how to remove the fuse box and thT one wire. Don't want to have to replace all the wires if I can just figure out how to replace that one
  10. #10 Re: Engine fusebox wires melted
    Houston
    If there is a part that isn't melted at the battery terminal, you COULD cut the wire off there and solder in a new one. I would replace them all, grounds and all.
    Dec 2010
    DMV
    Ok. I'll give it a look around in a bit. Thanks.
    Dec 2010
    DMV
    Ok, upon further inspection I can see that soldering is our of my skill set. The wire is still intact it's just thT the insulation surrounding the wire is gone. What's a good fix to re insulate the wires? Rather not go to a shop
  13. #13 Re: Engine fusebox wires melted
    pic of where that wire goes?
    Dec 2010
    DMV
    Gimme a few and I can post it. Kinda on duty but scared to drive it home lol.
  15. #15 Re: Engine fusebox wires melted
    soldering wires is more then easy to do. a cheap soldering iron is like 10 bucks, the flux core solder is about 5, the shrink wrap about 5 also for a box of tubes, and then the wire to replace what malted.
    heres a vid, this is how like to twist the wires. i use flux core solder tho, so no mess with the flux. just heat up the wires touch the solder and it spreads.
    and the wires had a melt down for a reason, you need to find out why, chaffed wires bad grounds, over loaded wires.
    good luck.
    Dec 2010
    DMV
    Wire connects to positive battery cable. It's the cable that starts at the battery cable and leads to the top of the fuse box
  17. #17 Re: Engine fusebox wires melted
    That's not good. It's grounding out somewhere and by the burn mark on your hood i'd say it's hitting there.
    Dec 2010
    DMV
    Yup. I'm thinking it was the amp wires that was on that same location. I removed the amp wire.
  19. #19 Re: Engine fusebox wires melted
    amp wire fused?
  20. #20 Re: Engine fusebox wires melted
    Houston
    Good call! I didn't even see the hood pic. Not sure how that wire could hit the hood though.
  1. Put a 2001 engine in a 1998 grand prix..help!!! Wires smoking
    By Djstanley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2012, 01:46 PM
  2. new fusebox cover and cross braces
    By beckys2000gt in forum Visual/Body Modifications
    Last Post: 06-26-2010, 10:12 AM
  3. new engine cover, braces n fusebox cover
    Last Post: 05-27-2010, 09:40 AM
  4. Custom Fusebox & Underhood Lining
    By Spartan GL in forum Visual/Body Modifications
    Last Post: 01-20-2010, 12:16 AM
  5. sparkplug melted
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 04-12-2009, 05:22 PM
