Thread: Fixed my problem. Now tell me how to shut my flowmaster 44s up
Results 1 to 20 of 22
  1. #1 Re: Stange high pitched chirping/ squealing noise from the top end around the pulleys
    hes got the ssm90 kit, one belt.
  2. #2 Re: Stange high pitched chirping/ squealing noise from the top end around the pulleys
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Oh yeah...
    Quote Originally Posted by JDrach View Post
    Could a bad idler cause slippage, which may result in delayed boost and reaction of the torque produced? I too have something squealing around my SC hub. And have noticed when i go WOT theres a slight delay. Unless its just all my timing :P
    You're not feeling the transmission downshifting as your delay, are you?
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  1. Weird problem after i though i fixed it...
    By 73pontiac in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-31-2011, 10:43 AM
  2. a/c mode problem fixed!!!
    By Randy GP in forum General Tech Discussion
    Last Post: 10-16-2010, 01:57 PM
  3. My stalling problem not fixed!
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-02-2010, 05:22 PM
  4. Problem - Can't shut off my vents - 2006
    By Vinton GP in forum General Tech Discussion
    Last Post: 03-26-2009, 01:28 PM
