Thread: cruise controle not working
Results 1 to 14 of 14
  1. #1 cruise controle not working
    Jul 2013
    ohio
    I have a 2000 gtp with 90k mile. i got the car about 3 months ago and the cruise control hasn't worked at all im trying to find out the easiest way to fix it. i was reading some post and some similar problems was caused by a bad break light. im pretty sure all my lights work and the fuse is good too. not sure where the cruise control module either. should i jus replace it right off the bat or how could i find out if its something else causing it to go out. i got a service engine light that came on with the code p1887 which is the TCC (torque converter clutch could this make my cruise not work? any information would b great thanks for reading hope i get some responds.
  2. #2 Re: cruise controle not working
    Not sure on the TCC keeping it from working. It may.
    Step one..lift the hood and see if the cable from the cruise module to the throttle body is connected. It's common for someone to break the end on the cable when doing work on the car if they are new to it.
    Step two.. google that code and see if anything suggests cruise won't work.
  3. #3 Re: cruise controle not working
    GTP Level Member
    springfield IL
    The arm that has the wipers,cruse, etc etc on my 00' is very lose.... Cruse doesn't work that a sign of broken cable??
  4. #4 Re: cruise controle not working
    Jul 2013
    ohio
    will do thanks ill let u know what i see
  5. #5 Re: cruise controle not working
    Okay..try not to get dizzy if you follow the cables..they do a loop or two.
  6. #6 Re: cruise controle not working
    Jul 2013
    ohio
    yea the cable was disconnected from the throttle body hope that works will find out in a few but i was looking under my car near the driver fog light an there is a plug that is just hanging there. the rubber connecter part is red an it had PED on it an a number 13 any ideas what that could be?
  7. #7 Re: cruise controle not working
    Does that fog light work?
  8. #8 Re: cruise controle not working
    Jul 2013
    ohio
    no neither of them do but there is a red and black wire going to the socket where the light connects at. idk if that wire connects to them or not was looking for bout 15 min couldn't see anything that it could plug into
  9. #9 Re: cruise controle not working
    Hmmm I'd suggest getting a picture of the connector and posting it to the electrical section as a new thread. The title on this one may keep the connector guys from looking at it.
    Gotta love the easy cruise fix though.
  10. #10 Re: cruise controle not working
    Jul 2013
    ohio
    yea tell me about something so simple lol its never like that but like u said i love it when it is
  11. #11 Re: cruise controle not working
    Jul 2013
    ohio
    thanks for your help again bill
  12. #12 Re: cruise controle not working
    np..now that I got you to post a picture..I'll go try and answer taht
  13. #13 Re: cruise controle not working
    Feb 2013
    37.295091, -121.930053
    bill just wave your magic wand over it and make it disappear
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  14. #14 Re: cruise controle not working
    No, it's a sign of a lot of use.
  1. cruise control not working and i need it back?
    By tyler sharp78 in forum General Tech Discussion
    Last Post: 06-14-2014, 01:26 PM
  2. Cruise control not working as well as hud!!
    By HughJhas in forum How To Write-Ups/Tech Tips
    Last Post: 03-24-2013, 12:04 PM
  3. My Cruise is not working. please read.
    By b72hugh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2013, 03:24 AM
  4. Cruise Control Not Working
    By Curt7 in forum General Tech Discussion
    Last Post: 07-07-2011, 08:10 PM
  5. Why is my cruise control not working?
    By bronzegp in forum General Tech Discussion
    Last Post: 04-12-2011, 05:44 PM
