Thread: My Cruise is not working. please read.
Results 1 to 20 of 32
  1. #1 My Cruise is not working. please read.
    Jul 2012
    Saskatchewan, Canada
    I have recently bought a 98 GTP.
    The cruise worked when i bought it.
    I have changed the front wheel bearings and axle shafts on both sides.
    The tail lights all work.
    The fuse in the glove box is good.
    The other day i shifted into neutral while the car was moving and the speedo went to zero.
    Any ideas why the cruise doesn't work.
  2. #2 Re: My Cruise is not working. please read.
    Ohio
    engine light on?
  3. #3 Re: My Cruise is not working. please read.
    Jul 2012
    service engine soon light? it is on. codes are for O2 sensor. next on the list.
  4. #4 Re: My Cruise is not working. please read.
    Is it still attached and together?
    Did you shift it into N with the cruise engaged?
  5. #5 Re: My Cruise is not working. please read.
    Jul 2012
    Is what attached? The clip on the throttle body?
    It is.
  6. #6 Re: My Cruise is not working. please read.
    Jul 2012
    and the cruise was not on. Is there an indicator light that the cruise is active? i cant remember.
  7. #7 Re: My Cruise is not working. please read.
    Grand Rapids, MI
    Have you reset it by switching it to the off position and then back to the on position?
  8. #8 Re: My Cruise is not working. please read.
    Jul 2012
    yep i sure have. about a hundred an forty two times. lol
  9. #9 Re: My Cruise is not working. please read.
    green light on the dash, usually says "cruise" at least the regal does, but most GM cars light up in the dash cluster.
  10. #10 Re: My Cruise is not working. please read.
    Jul 2012
    i thought there should be, but i dont have one. it is only on when the cruise is engaged though, correct? not on when it is 'ready'.
  11. #11 Re: My Cruise is not working. please read.
    yeah, i think so, you need to be doing 30 or 35 mph before it will work. maybe faster. its not for local driving.
    the way i use it is to slide the switch over, get up to the speed i want, then hit the button on the end to set my speed.
    you can also push the switch more and it will make the car go faster.
    hold the end button in and it will coast. or tap the brake and it turns off.
  12. #12 Re: My Cruise is not working. please read.
    Jul 2012
    right, i have tried every time i take it out. is there more than one speed sensor? seems odd that the speedo would drop to zero just because the tranny was in neutral.
  13. #13 Re: My Cruise is not working. please read.
    yeah that is kinda mess up.
    so the speedo only dropped to zero the one time, or its like that all the time now? if the speedo's not working im sure the cruise would fail as well.
  14. #14 Re: My Cruise is not working. please read.
    Jul 2012
    it only drops when coasting in neutral. put it back in drive and its fine. i will check in reverse later. lol
  15. #15 Re: My Cruise is not working. please read.
    There is no indicator light that i am aware of on 97-03 gps
  16. #16 Re: My Cruise is not working. please read.
    Jul 2012
    How often have you guys heard of the box on the fender going bad? sorry for the technical jargon!lol.
    i have an extra car. guess i will swap it out.
  17. #17 Re: My Cruise is not working. please read.
    Donating Users ARFF22's Avatar
    NEW YORK
    Quote Originally Posted by b72hugh View Post
    Mine went bad on my 01 with about 140k miles on it. They are easy to find all over E-Bay, picked up a replacement for $19 bucks. Took about 5-10 minutes to swap out and all is fine now. May be worth just picking one up to help trouble shoot, I'm sure you can turn it around if you need to unload it?
  18. #18 Re: My Cruise is not working. please read.
    sorry, no idea where to tell you to turn to next. thats just odd.
    GT Level Member Utter99's Avatar
    Warsaw indiana
    My speedo goes to zero when I put it in nutral and then some other times it still says my speed
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  20. #20 Re: My Cruise is not working. please read.
    Hopefully you can figure this out, but one thing to note, dont put your car in neutral and start coasting for whatever reason. Everytime you put it back in gear you are wearing out other parts of the trans more. When you let off the gas and just coast as normal with the trans still in gear the car goes into a fuel cut off mode on its own untill you get back on the gas.
  1. Replies: 3
    Last Post: 07-24-2012, 08:41 AM
  2. Cleaned my throttle body..cruise control stops working
    By GTLGDP in forum General Tech Discussion
    Last Post: 03-21-2012, 04:31 PM
  3. Cruise Control Not Working
    By Curt7 in forum General Tech Discussion
    Last Post: 07-07-2011, 08:10 PM
  4. Why is my cruise control not working?
    By bronzegp in forum General Tech Discussion
    Last Post: 04-12-2011, 05:44 PM
  5. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
