Thread: Replaced sc spit fluid everywhere and killed on startup
Results 21 to 40 of 52
  1. #21 Re: Replaced sc spit fluid everywhere and killed on startup
    GT Level Member Beelzeboul's Avatar
    Racine
    yeah I just wanted the sound difference to be apparent after installing that vac tree cause it obviously sounds alot better I was able to trace the fuel squiting from what I think is the return line . its a black bolt on one side and a metal tube coming of the otherside of bracket and the black bolt itself is where it is squirting out gonna try tightening it up and otherwise finding out how to replace the seal on it
    thats the culprit i believe
    what really bothers me is the car won't turn over and yet I get no codes while scanning..
    I'm sorry officer I didnt know I couldn't do that
  2. #22 Re: Replaced sc spit fluid everywhere and killed on startup
    Houston
    Thats your EGR, it shouldn't be spitting out fuel.
  3. #23 Re: Replaced sc spit fluid everywhere and killed on startup
    Racine
    well I went and tried it again and its not spitting fuel out but it has liquid in the line cause it was hissing and seemed like gulping before it let out a bunch of goup it could be running down and over the top of it and I cant see but it really sounds and looks like its coming from there not the bolt either the actual line i'll post a video of it in the daytime but its dark out there right now gonna probably go boorow gfs camera too phones just dont do the trick
  4. #24 Re: Replaced sc spit fluid everywhere and killed on startup
    Houston
    If the EGR tube does have a hole in it, the worst you would get is a small vac leak. Not sure why you would have fluid coming out of it. The only thing that runs through that tube is spent exhaust. Unless you don't have spark and the fuel is getting sent out the exhaust valve and going through your EGR. Not sure how likely that is.
  5. #25 Re: Replaced sc spit fluid everywhere and killed on startup
    Racine
    is there anything above or around that could possibly be spraying onto the nut and tube ? like I said this is directly below my TB and running down either side of the engine from there but nothing above or on other side visible hopefully the video tomorrow will give someone a light bulb even if it isn't me
  6. #26 Re: Replaced sc spit fluid everywhere and killed on startup
    Houston
    Not fuel. The fuel runs from the fuel rails to the injectors.
  7. #27 Re: Replaced sc spit fluid everywhere and killed on startup
    are you 100% sure its gas?
    sounds like the TB is leaking coolant, like as in a bad gasket. there really isn't any gas to leak from there.
    has this car started yet? or still just cranking and no start.
  8. #28 Re: Replaced sc spit fluid everywhere and killed on startup
    Racine
    yeah it is coolant must have just had the gas fumes from trying to start it in garage repeatedly that and the fact that its clear but walking out there now all I can smell is coolant no gas at all it was also alot thicker
    reading now into an upper plenum gasket failure not sure it that seems appropriate or not
  9. #29 Re: Replaced sc spit fluid everywhere and killed on startup
    your TB has coolant passages to it, if the gasket is not sealed well it can leak coolant right from under the TB where it meets the blower.
  10. #30 Re: Replaced sc spit fluid everywhere and killed on startup
    Racine
    ok I should have at least rtv sealed this when I put new sc on didn't notice a gasket there for sure though thanx alot scotty hopefully its the gasket
    I saw a pic where the guy removed his cone from intake and actually had a bunch of coolant trapped in the tubing which is almost exactly what it sounds like from under the hood hopefully this is the cause of my no start but I'll letcha guys know tomorrow for sure gonna look for a write up on changing out the gasket on it if anyone has any links I would be most appreciative
    ummm ps how terrible is it going to be if my engine was sucking up coolant from intake......
  11. #31 Re: Replaced sc spit fluid everywhere and killed on startup
    Houston
    Just Hydrolock.....lol
  12. #32 Re: Replaced sc spit fluid everywhere and killed on startup
    Quote Originally Posted by Beelzeboul View Post
    not recommended.
  13. #33 Re: Replaced sc spit fluid everywhere and killed on startup
    Racine
    any precautions I should take after replacing the the TB gasket ?
    took off TB it had liquid inside but not enough to puddle or anything just enough to make moisture apparent
  14. #34 Re: Replaced sc spit fluid everywhere and killed on startup
    some will spill out, its normal, dont worry.
  15. #35 Re: Replaced sc spit fluid everywhere and killed on startup
    Racine
    as far as trying to get any coolant that may already be in there out though not many options?
    also do I have to order a gasket or will most parts stores have one for me
  16. #36 Re: Replaced sc spit fluid everywhere and killed on startup
    your not following here, its supposed to have coolant in there, its supposed to help cool the TB. if your gasket is leaking it will leak under the Tb, and maybe inside it.
  17. #37 Re: Replaced sc spit fluid everywhere and killed on startup
    Racine
    ok gotcha so it should be minute lvls of coolant if any that got sucked in with intake. sorry to talk in circles its been a long day and I have yet to air condition my garage :P
  18. #38 Re: Replaced sc spit fluid everywhere and killed on startup
    Racine
    VID_20120805_142858.mp4 video by beelzeboul - Photobucket
    replaced throttle body gasket and its doing a little better now still cant get and codes out of it is it possible some coolant may have gotten sucked though intake and mucked up my maf causing this?
  19. #39 Re: Replaced sc spit fluid everywhere and killed on startup
    seriously check you plug wires.
  20. #40 Re: Replaced sc spit fluid everywhere and killed on startup
    Racine
    just went and check all the plugs and wires getting underneath I couldnt believe how much coolant I spit out yesterday trying to start with bad TB gasket. gonna go pick up a bottle as my reservoir was almost dry is there a safety that would keep the car from turning over if deadly low on coolant?
    gonna go pick up a bottle or two now and fill it up
  1. 97 gtp. Sputters on startup
    By djs4021 in forum General Tech Discussion
    Last Post: 10-26-2011, 12:55 PM
  2. 2 stangs, killed and got killed
    By Boosted02GTP in forum Track Sessions and Kills
    Last Post: 10-30-2010, 08:28 PM
  3. Startup issue with the GTP
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-29-2010, 09:53 PM
  4. Bad lag on startup & accelleration
    By Jsedor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2009, 03:07 PM
  5. oil burn at startup?
    By Golgo13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2008, 07:18 PM
