Re: Replaced sc spit fluid everywhere and killed on startup
yeah I just wanted the sound difference to be apparent after installing that vac tree cause it obviously sounds alot better I was able to trace the fuel squiting from what I think is the return line . its a black bolt on one side and a metal tube coming of the otherside of bracket and the black bolt itself is where it is squirting out gonna try tightening it up and otherwise finding out how to replace the seal on it
http://i1013.photobucket.com/albums/...804_202353.jpg
thats the culprit i believe
what really bothers me is the car won't turn over and yet I get no codes while scanning..
Thats your EGR, it shouldn't be spitting out fuel.
well I went and tried it again and its not spitting fuel out but it has liquid in the line cause it was hissing and seemed like gulping before it let out a bunch of goup it could be running down and over the top of it and I cant see but it really sounds and looks like its coming from there not the bolt either the actual line i'll post a video of it in the daytime but its dark out there right now gonna probably go boorow gfs camera too phones just dont do the trick
If the EGR tube does have a hole in it, the worst you would get is a small vac leak. Not sure why you would have fluid coming out of it. The only thing that runs through that tube is spent exhaust. Unless you don't have spark and the fuel is getting sent out the exhaust valve and going through your EGR. Not sure how likely that is.
is there anything above or around that could possibly be spraying onto the nut and tube ? like I said this is directly below my TB and running down either side of the engine from there but nothing above or on other side visible hopefully the video tomorrow will give someone a light bulb even if it isn't me
Not fuel. The fuel runs from the fuel rails to the injectors.
are you 100% sure its gas?
sounds like the TB is leaking coolant, like as in a bad gasket. there really isn't any gas to leak from there.
has this car started yet? or still just cranking and no start.
yeah it is coolant must have just had the gas fumes from trying to start it in garage repeatedly that and the fact that its clear but walking out there now all I can smell is coolant no gas at all it was also alot thicker
reading now into an upper plenum gasket failure not sure it that seems appropriate or not
your TB has coolant passages to it, if the gasket is not sealed well it can leak coolant right from under the TB where it meets the blower.
ok I should have at least rtv sealed this when I put new sc on didn't notice a gasket there for sure though thanx alot scotty hopefully its the gasket
I saw a pic where the guy removed his cone from intake and actually had a bunch of coolant trapped in the tubing which is almost exactly what it sounds like from under the hood hopefully this is the cause of my no start but I'll letcha guys know tomorrow for sure gonna look for a write up on changing out the gasket on it if anyone has any links I would be most appreciative
ummm ps how terrible is it going to be if my engine was sucking up coolant from intake......
Beelzeboul
not recommended.
any precautions I should take after replacing the the TB gasket ?
took off TB it had liquid inside but not enough to puddle or anything just enough to make moisture apparent
some will spill out, its normal, dont worry.
as far as trying to get any coolant that may already be in there out though not many options?
also do I have to order a gasket or will most parts stores have one for me
your not following here, its supposed to have coolant in there, its supposed to help cool the TB. if your gasket is leaking it will leak under the Tb, and maybe inside it.
ok gotcha so it should be minute lvls of coolant if any that got sucked in with intake. sorry to talk in circles its been a long day and I have yet to air condition my garage :P
VID_20120805_142858.mp4 video by beelzeboul - Photobucket
replaced throttle body gasket and its doing a little better now still cant get and codes out of it is it possible some coolant may have gotten sucked though intake and mucked up my maf causing this?
just went and check all the plugs and wires getting underneath I couldnt believe how much coolant I spit out yesterday trying to start with bad TB gasket. gonna go pick up a bottle as my reservoir was almost dry is there a safety that would keep the car from turning over if deadly low on coolant?
gonna go pick up a bottle or two now and fill it up
