Thread: Oil Pressure SPIKE THRU THE ROOF
Results 1 to 12 of 12
  1. #1 Oil Pressure SPIKE THRU THE ROOF
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    03 GTP 128K.
    P.O. installed Autometer 5727, short sweep electric Oil Pressure guage, 0-100 PSI. Had car for 1 yr and guage always worked good, typ reads 50-75 psi.
    I just finished differential install. In order to reach the parts, I drained oil and removed oil filter and oil pressure sending unit.
    On first test drive I noticed oil pressure guage was burried past 100psi. Then in a minute, it dropped and jerked back up, repeated. I thought I would let it warm up, pump new oil thru engine. & guage did return to normal in few minutes--big relief. No problems on test drive.
    Then this morning, coming to work, guage spiked again, burried past 100psi and stayed there, even at idle... Engine seems to run fine, but this can't be good.
    Few monthes ago, piece of plastic from my dipstick broke, lost in the tube, presumbly in pan. I changed oil couple of time since, have not had any problems like this before. Is it possible to thread sending unit in too far, or too tight?
    Can anyone shed some light on this? Could really use help to get this solved...
  2. #2 Re: Oil Pressure SPIKE THRU THE ROOF
    its electric.
    could be a short.
    inspect wiring.
    Plastic piece would get stuck on strainer, won't go anywhere.
  3. #3 Re: Oil Pressure SPIKE THRU THE ROOF
    Nov 2011
    Chicago
    Hey thanks Matt! I was freaked out by palstic at first, but info on this forum helped put my mind to ease. But w/ this issue, I thought I should mention it...
    I'll pull wheel and get my multimeter...
  4. #4 Re: Oil Pressure SPIKE THRU THE ROOF
    AGree wtih Matt's assessement. It's likely electrical/loose wire
  5. #5 Re: Oil Pressure SPIKE THRU THE ROOF
    Nov 2011
    Chicago
    ok, so thinking about it a little. Is this a electrical issue w/ guage, or w/ oil pressure sending unit itself (I don't know how unit works)?
  6. #6 Re: Oil Pressure SPIKE THRU THE ROOF
    rent a mechanical pressure tester to see what it really is.
    you remove the sensor and screw it into the same place.
    depending how old your gauge is the sensor could be failing. or a wire got burnt up. or your wiring is melting on something or cut and grounding.
  7. #7 Re: Oil Pressure SPIKE THRU THE ROOF
    St. Louis
    If that sending unit is the same size as the one for my Sport-Comp gauge then it's possible that the wire got ripped or frayed by something under there. IIRC its a tight fit with all the other stuff back there.
  8. #8 Re: Oil Pressure SPIKE THRU THE ROOF
    Nov 2011
    Chicago
    update, and more problems.
    I checked wire @ sending unit & tightened nut. guage worked for 1 day. then spiked past 100psi & stayed there. I took another look, & found wire insulation was cracked & bare wire was touching 1 of the steel lines. So I tried to remove nut, to tape wire insulation, except this time the nut would not come free and entire thing spins when I turn wrench. Finally got it off, & taped wire.
    In the process, I loosened entire outer bolt from cylinder/body portion of sending unit. Now guage does not move, reads 0 all the time. I think I broke the sending unit..... first things first, then I'll get to fixing it.
    Can I safely drive my car?
    Thanks, could really use input, have not been able find info on how the sending works/how it affects engine.
  9. #9 Re: Oil Pressure SPIKE THRU THE ROOF
    sounds like you should be good to go. get the sending unit replaced and go from there.
  10. #10 Re: Oil Pressure SPIKE THRU THE ROOF
    Stock there is no gauge, so as long as you plug that hole with either your defective unit or something else..you should be fine.
  11. #11 Re: Oil Pressure SPIKE THRU THE ROOF
    Nov 2011
    Chicago
    Just an update. & to say, THANKS AGAIN.
    Breaking my oil pressure sending unit, ~$40, spurned me into replacing PO's guages to something closer to my personal pref. PFYC.com Z series autometer. The font does not match, but IMHO the colors work much better. I'll probably spring $25 for the amber LEDs before I'm thru. & I'm glad to NOT to have the LED flashing light show in my face anymore. All in all, I'm real happy I finally got this off my to do list.
    New b/v guage was bouncing and sticking. I found a tip on "proper" place to T into b/v line for guage, moved T from under snout to end of line on the back side and ran the new nylon tubing that came with new guage. Works great now!
    A few pics, before and after.
    My ABS & TCS OFF lights are like old friends now.
  12. #12 Re: Oil Pressure SPIKE THRU THE ROOF
    St. Louis
    Lol at the ABS/Trac Off. Mine's been on for almost 4 months now. Just got around to messing with it and found the pass. front hub has some nice play in it. Time for a Timkin.
  1. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  2. sun roof
    By Wadeb79 in forum General Tech Discussion
    Last Post: 07-20-2010, 11:46 PM
  3. 97 GTP Coolant leaking and Temp spike
    By graham25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2010, 10:49 AM
  4. heat spike
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2010, 12:03 AM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
