Thread: Two Questions Key Fob and Fan
Results 1 to 4 of 4
  1. #1 Two Questions Key Fob and Fan
    Sep 2012
    Gravelbourg, Saskatchewan
    My son bought a 2003 Grand Prix GT and he does not have a key fob. Are they easilu purchased and programmed?
    Second question. The fan is not really noticeable unless it is turned up to five. The A/C button seems to only work some of the time Does he need a new fan? Does his climate control cluster need to be replaced?
    Thanks in advance.
  2. #2 Re: Two Questions Key Fob and Fan
    St. Louis
    If it has remote keyless entry, then yes you can order one from Ebay and program it. There are programming instructions here on the site.
    The fan issue is probably a bad blower motor resistor. Common issue on these cars.
    Not sure about the A/C button issue. Never had a problem with one. I'd fix the blower issue first and go from there.
  3. #3 Re: Two Questions Key Fob and Fan
    Sep 2012
    Is there any way to tell if this vehicle has Keyless Entry? I just thought that was a standard feature on them?
  4. #4 Re: Two Questions Key Fob and Fan
    St. Louis
    Look on the inside of the trunklid for a Service Parts Identification Label. It has a list of RPO (Regular Production Option) codes. You can google for a GM RPO decoder.
    For example, the codes for a '98 are:
    AU0 Lock Control, Remote Entry
    A90 Lock Control, Rear Compartment Lid
    Remote Control Electric Release
    UA6 Theft Deterrent System
    Then use this link to program the new fob-- http://www.grandprixforums.net/how-p...fob-53653.html
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. A few GXP questions
    By black954 in forum General Tech Discussion
    Last Post: 11-16-2011, 12:05 AM
  3. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  4. more questions
    By EmEaston24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2009, 08:44 AM
  5. A few questions
    By Shaunk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2009, 09:36 PM
