Thread: heads up switch????????
Results 1 to 15 of 15
  1. #1 heads up switch????????
    Jul 2012
    Indiana
    i have a 02 grand prix gt 3.8 it dosent have the heads up display but i really want to install one.....would i just be able to rip a dash assembly with one out of a car at a junk yard and install it in my car?? if so would it matter if i use a certian year or model like can i use one from a gxp in a 97 or no? any info would be appreciated thanks
  2. #2 Re: heads up switch????????
    Houston
    I got mine out of a 98 in a junkyard. You need the display unit, the dash piece and switch. You may want to see if your car is prewired for it. This is how I did mine. On page 4
    http://www.grandprixforums.net/keith...s-4-46697.html
  3. #3 Re: heads up switch????????
    Jul 2012
    Indiana
    @keithGTP03 if its not pre wired is there a chance it can be hardwired in?
  4. #4 Re: heads up switch????????
    Quote Originally Posted by jward2155 View Post
    yes you can, there is a how to posted here somewhere.
    some cars come with the plug/pre wired, (im not 100% sure but the plug may be right behind the cluster) if not you need to cut and splice for the plug for the heads up display.
    theres a how to, to make a harness and where to splice it and what to cut and install. im pretty sure its a Billboost37 how to.
    if you need to cut and splice, do solder your splices and use shrink wrap on the connections, it will last years longer than any other method.
    and i hear the heads up display can be found used at a fair price, some have picked them up for 50 or less. its all about shopping.
  5. #5 Re: heads up switch????????
    Houston
    Correct. It will be right behind the gauge cluster and the other harness will be behind the cubby on the right of the steering wheel. This is behind the cluster. This goes to the display unit. If you have this, you are wired for it.
  6. #6 Re: heads up switch????????
    Houston
    Yes. Here is that info.
    ClubGP Message Forum troubleshooting
  7. #7 Re: heads up switch????????
    sadly ive had my regal cluster out, and i got nothing back there...
  8. #8 Re: heads up switch????????
    Jul 2012
    Indiana
    I have no plug jus wires that go into the cluster and my foglight wires
  9. #9 Re: heads up switch????????
    Houston
    Then you're gonna need to grab the pigtails also. (the one behind the cluster and the one behind the right cubby that's attached to the Hud switch/controller)
  10. #10 Re: heads up switch????????
  11. #11 Re: heads up switch????????
    Jul 2012
    Indiana
    @ scottydoggs is this the exact same for the 02 grand prix gt?
  12. #12 Re: heads up switch????????
    it should be, being that in the write up i think he said he just matched up the wires.
    and being your in a gp, the wires should be dead on. color wise. you'll learn a lot more when you are removing the one your buying, thats for sure.
    the install is about the same i guess, being both are W bodys on the same frame.
    cutting the dash would be the scary part to me lol
  13. #13 Re: heads up switch????????
    I have everything you would need to do it if your interested pm me.
  14. #14 Re: heads up switch????????
    Jul 2012
    Indiana
    UPDATE......so i went to the junk yard and pulled the hud projector, switch and both pigtails.........not i have no idea how to wire it the post from billboost 37 says i only need to attach like 5 wires but i have no idea where due to having 2 plugs in the back of my cluster and i noticed while pulling the one from the junk yard that some go to one connector and some to another.....another problem im having is on the pigtail from the switch there are black, red/pink, and greyish wires that i have no idea where to connect and his post dosent say.........plz help
  15. #15 Re: heads up switch????????
    Dec 2008
    Lawndale, CA
    All you need
  1. Help on crack heads..need advice on l26 heads
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2013, 10:07 AM
  2. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  3. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  4. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
