ICM is under the coil packs. On the front facing the radiator is a 7mm holding the connector on it. I disconnect that.
I crank a while... let off...crank..let off... repeat a bunch of times. Supposedly it's quick to prime. you could use a gauge to tell for sure..I never do and then... reconnect and fire it up.
