Thread: lower intake manifold might be leaking...
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 103
  1. #1 lower intake manifold might be leaking...
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    Can you guys give me some advice on what i should replace if I needx a to replace the seals.. parts, etc... I understand there is whole upper manifold to put on.. its a better part or something. What are the othe parts ffom zzp that is supposed to help performance?
  2. #2 Re: lower intake manifold might be leaking...
    Omaha, NE
    If you're N/A you can upgrade to the metal L26 upper intake manifold.
    Besides that all you need is a lower intake manifold gasket, an upper intake (or supercharger) gasket, and some RTV.
    Ohio
    Fixed
  4. #4 Re: lower intake manifold might be leaking...
    Omaha, NE
    Looks like a direct quote...
  5. #5 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    Yes N/A.. what about some performance parts I saw? I'm being quoted $825.0 for lower seals orings gaskets and upper manifold.. thoughts? The mechanic also mentioned it might be something.. I hope so.. how long can I wait to do this? Its not leaking all that bad..
  6. #6 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    I know I missed it to... l26 and l32
    Ohio
    Now it does ;p you silly
  8. #8 Re: lower intake manifold might be leaking...
    Quote Originally Posted by andremike View Post
    825!!!!! you could do it yourself for under 150 i bet ....with a new intake...shops suck so bad.....
  9. #9 Re: lower intake manifold might be leaking...
    Omaha, NE
    Which performance parts? There are a lot of them...
    In my opinion 825 is ridiculous! You could do it yourself with a basic tool set for under $200 in maybe 4 hours if it's your first time.
    Might be something....??????
    This would be something you would want to do right away. Oil is getting in your coolant and coolant is getting in your oil. This can jam up the rcooling system and "dry" your oil, which reminds me, add Oil and an oil filter as well as coolant and a new thermostat to your shopping list.
  10. #10 Re: lower intake manifold might be leaking...
    most here recommend doing 2 oil changes as well as dump in a few quarts down the lifter valley to wash any coolant out of your engine.
  11. #11 Re: lower intake manifold might be leaking...
    Omaha, NE
    While you're in the lifter valleys, dont' forget to change the valve cover gaskets too.
  12. #12 Re: lower intake manifold might be leaking...
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    i did all of the above. i bought everything above but did one oil change. my oil was synthetic and everything i bought including a can to a paint my vavle covers red was 200 bucks. a gm dealership quoted my 700 dollars but i got the quote just to see how much money id be saving and i saved my self 500 bucks or more if you include the face that they quoted me the job without a new tstat, synthetic oil, painted valve covers along with doing the gasket job!!!. doing the gasket job probably wouldved been 900 bucks at a dealership. but i cant believe a regular shop charged you that much. very ridiculous
  13. #13 Re: lower intake manifold might be leaking...
    Omaha, NE
    Labor rates aren't cheap. You may want to shop around for a different mechanic.
  14. #14 Re: lower intake manifold might be leaking...
    most shops like dealers charge the book rate for hours on a job, so if the book calls for 4 hours you are paying for those 4 hours, it dont matter it it only takes 2 hours, you pay for the 4.
    the mechanics make all them extra hours too, they get paid by the book hours for each job they do, at the dealer anyways.
  15. #15 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    That price was with the whole upper manifold to.. replacing it with the new one.. he also told me about some o rings or something where the alternator screws in... ill try to talk them down...
  16. #16 Re: lower intake manifold might be leaking...
    buy a used intake and have them put it on if your not up to it, please shop around tho, i hate to see people get raped that hard.
    and it would seem your dealing Mandingo. lol
  17. #17 Re: lower intake manifold might be leaking...
    Nov 2010
    Illinois
    hes getting raped with no lube lol
    those "o-rings" by the alternator are probably the coolant elbows that he's referring to. its like 5.99 please shop around so if your gonna get raped at least they'll use lube lol
  18. #18 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    I wasn't expecting the negative comments.. the dealer wanted even more ithink closer to 900. and it didn't include the upper manifold or coolant elbows.. ill have to call them back and see if they can do any better. They did say it should take about 4 hours.
    If anyone can do it for cheaper let me know... this isn't something I want to attempt...
  19. #19 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    im trying to find all the parts on Rockauto... can someone tell me the parts I need? I'm curious how much in parts there are...
    Looks like a $125.00 in parts.. come on got be more than that..
  20. #20 Re: lower intake manifold might be leaking...
    no its not...hence the raping.
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. lower intake manifold job
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 10:22 PM
  3. Lower Intake Manifold
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 10:44 PM
  4. Lower intake manifold
    By FuglyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 10:40 AM
  5. leaking intake manifold
    By chrizzle17 in forum General Tech Discussion
    Last Post: 01-09-2009, 11:30 AM
