Thread: Window seized at bottom help me get it back up
Results 1 to 7 of 7
  1. #1 Window seized at bottom help me get it back up
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Help me guys I need to get this window up by tomorrow. The window motor seized at the bottom and the window can't be forced up at all. Do I cut the wires to it and brace it up
  2. #2 Re: Window seized at bottom help me get it back up
    Ocala, FL
    Make it simple, just remove the regulator, it will disattach from the window.
    Its just a few bolts, a few hold the regulator in place, and a few hold the motor in place, just remove both.
    Then when you have the money for a regulator you just install that one.
    Cutting the cables would work too, but just get the regulator out of the way, it'll take just a few minutes.
    Mar 2012
    Minneapolis MN
    How do I get those both out though? Can I do it without taking the inner metal door panel out?
  4. #4 Re: Window seized at bottom help me get it back up
    GTX Level Member blackflag's Avatar
    Virginia
    Try slamming the door real hard a couple times. Shorts, Ftl
  5. #5 Re: Window seized at bottom help me get it back up
    St. Louis
    Well, for one you cannot take the inner metal door panel out. It is part of the door. If you cannot access the 2 bolts that hold the glass to the regulator then you might be able to just remove the window motor and push the glass up that way. The regulator should move w/ the motor off of it.
  6. #6 Re: Window seized at bottom help me get it back up
    Ocala, FL
    Quote Originally Posted by FordMan77 View Post
    Just removing the motor won't help, it's attached to the regulator. He needs to remove the regulator, the regulator removes with 2-3 bolts, and the motor removes with 2-3 - all as one assembly.
    Just take a look at it, it's really not that complicated. Once you have the door panel off, peel the protective plastic back and look at what is inside the door(it's all just simply the door, as said theres no separate panel). There are a few (I think 10mm?) bolts holding each the regulator and motor in place.
    Mar 2012
    Minneapolis MN
    Took both of them out. Motor was deadly hot and regulator was frozen. Also, after the tension was released from the wires holding the pulley together it all went to crap. Now I have a steel wire mess. But hey the window is up and supported by blocks of wood lol
  1. How to get paint off your back window?
    By str3etgl0w in forum General Tech Discussion
    Last Post: 08-29-2011, 02:41 AM
  2. Engine seized?
    By seanparker3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 12:52 AM
  3. Engine Seized
    By Green38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-09-2010, 01:33 AM
  4. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
  5. need help getting my back window back on track
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:06 PM
